What is this washer and Jet? Where do they go?
18 Jul 2011 23:21 - 19 Jul 2011 03:36 #463612 by Tested
ETA: I got a digital copy of the The 1977 KZ 750 B2 Service Manual form one of the guys over at That Kawai Twins forum. On page 40 of the .pdf it has a detailed break down of the carb and step by step instructions I can zoom in clearly on.
Like the title says?
I rebuilt my carbs this weekend and had these left over. Couldn't figure out where they went. BS 38 Carbs.
ETA: The washer is around 3/8" wide and the jet says 125 on it.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
Last edit: 19 Jul 2011 03:36 by Tested.
18 Jul 2011 23:51 #463620 by Patton
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
19 Jul 2011 00:01 #463623 by Tested
Patton wrote: Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Good Fortune! :)
I've tried that and can't see anything. Was hoping that one of the resident gurus would be able to point me in the right direction.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
19 Jul 2011 01:11 - 19 Jul 2011 01:13 #463647 by bountyhunter
Replied by bountyhunter on topic What is this washer and Jet? Where do they go?
The one on the right is a main jet. It's located at the bottom of the bowl above the drain screw. Stock will read 125. I think the washer goes under the brass seat the float works against. I think mine has a fiber washer there.
Last edit: 19 Jul 2011 01:13 by bountyhunter.
19 Jul 2011 03:08 #463668 by Tested
bountyhunter wrote: The one on the right is a main jet. It's located at the bottom of the bowl above the drain screw. Stock will read 125. I think the washer goes under the brass seat the float works against. I think mine has a fiber washer there.
Okay. I'll double check that jet in the bottom of the bowl when I am adjusting the floats tomorrow. The washer for the needle seat thing was already on it and I think the inside diameter was a little bigger but I will check that as well. Gonna try and get pics of where I put all the parts from the rebuild kit and maybe post them with some by the numbers instructions on how I rebuilt them. That way those with more experience can critique it and I can get better at it.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
19 Jul 2011 09:46 - 19 Jul 2011 15:20 #463694 by KZJOE900
Replied by KZJOE900 on topic What is this washer and Jet? Where do they go?
As bountyhunter already mentioned, it looks like a float needle seat washer and a main jet. Each of my kits came with two main jets (the stock 115 for my bike and an additional 118). Was this your situation?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 19 Jul 2011 15:20 by KZJOE900.
19 Jul 2011 16:34 #463782 by bountyhunter
The Keyster kits for the Mikuni BS-38 (750 twin) only come with the stock 125 main last time I bought them.
20 Jul 2011 01:23 #463870 by Tested
It was the washer for the drain plug and the main jet. Thanks for the help guys.
I put them in and adjusted the floats and she is screaming now. Haven't got her on the highway yet only 1st and 2nd around the neighborhood.
The love it when I tune the bike and cruise at 2200. I was to excited to wait until tomorrow.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
20 Jul 2011 11:22 - 20 Jul 2011 11:29 #463935 by Polar_Bus
Replied by Polar_Bus on topic What is this washer and Jet? Where do they go?
That looks like a Dynojet aftermarket main jet. What mm i.d is the washer ? I don't think it's a bowl drain plug gasket, the older KZ/GS carbs didn't have a drain plug.
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 20 Jul 2011 11:29 by Polar_Bus.
20 Jul 2011 17:34 - 20 Jul 2011 17:35 #463995 by bountyhunter
BS-38 carbs for the 750 twin do have drain plug and that does look like the washer for them. I forgot they came with metal washers because I pitched them decades ago and substituted fiber washers because the metal ones seep gas.
The main jet looks right as far as I can tell from the picture.
Last edit: 20 Jul 2011 17:35 by bountyhunter.
21 Jul 2011 06:47 #464096 by Polar_Bus
bountyhunter wrote: BS-38 carbs for the 750 twin do have drain plug and that does look like the washer for them. I forgot they came with metal washers because I pitched them decades ago and substituted fiber washers because the metal ones seep gas.
I was thinking of Mikuni VM carbs when I commented...:unsure:
Bikes:
'84 GPz1100
'06 HD Fatboy
