spectre 1100 coughing through carb during warm up
- garyprather
16 Jul 2011 12:47 #463156
by garyprather
spectre 1100 coughing through carb during warm up was created by garyprather
Ever since I bought this bike it pops through the carbs when warming up but does seem to clear up other than a cough every now and again. It seems to run fine at all levels of throttle. the bike was jetted and 4-1 mac put on with pods before i bought it. My spark plugs look great. I guess I am not to concered about this problem I was wondering if it is something that was inharrited from the mods. Any input would be great if anyone else has delt with this. BTW the carbs have been synced, cleaned, it does run great when warmed up. thanks.
- SlickRick6988
16 Jul 2011 15:20 #463169
by SlickRick6988
1977 KZ100A
Replied by SlickRick6988 on topic spectre 1100 coughing through carb during warm up
Have you done anything with the valves? my kz1000 does this same thing and i wonder if it is in the valve train maybe they need the lash adjusted if this is even possible. the other possibility is the o rings in the carbs may be leaking slightly. that could cause it too. it makes more sense that it would be in the valvtrain though because it almost clears up when its warm. ill check mine out and when i figure it out ill repost my solution.
1977 KZ100A
- Thank you received: 2098
16 Jul 2011 15:48 #463174
by Patton
Replied by Patton on topic spectre 1100 coughing through carb during warm up
If there's popping through the exhaust on deceleration with throttle closed, could enrich the pilot mixture (say 1/4 turn on each adjustment screw) and test ride.
- Thank you received: 2829
16 Jul 2011 16:53 #463184
by 650ed
Replied by 650ed on topic spectre 1100 coughing through carb during warm up
Check the carb holders for leaks. Set the idle as low as it will go and still run; spray carb cleaner around the joint where each carb holder mates with the head. If the engine dies or the idle changes, you have a carb holder leak and should replace the holders. Ed
- garyprather
17 Jul 2011 15:54 #463352
by garyprather
Replied by garyprather on topic spectre 1100 coughing through carb during warm up
I have tried that but did not adjust the idle down. Idle is running at about 900rpm. I did not notice any change in idle. The boots look fairly new also.
- garyprather
17 Jul 2011 15:55 #463353
by garyprather
The valves have been checked 2 of them was a bit tight but now they are all within spec.
- garyprather
17 Jul 2011 15:58 #463354
by garyprather
there is no poping through the exhaust on decel. that i notice. Over all it is only when warming up. I checked all the plugs during the warm up and after riding the seem to be firing nicely.
- draboo
- zzz
25 Jul 2011 13:48 #464797
by draboo
1983 KZ1100D Spectre shaft
Replied by draboo on topic spectre 1100 coughing through carb during warm up
I just purchased an 83 Spectre.Mine is completly stock. When cold, it does pop a bit. I thought it was just from being cold blooded. Runs great after warming up.
- garyprather
26 Jul 2011 00:34 #464967
by garyprather
I doesnt bother me at all it gives the bike character. Great bike.
- garyprather
11 Aug 2011 11:10 #468374
by garyprather
Just following up on this post here. I was able to adjust the air mixture to each carb clearing up the coughing coming from the carbs. It took me alot of time going back and forth to get it right. But as of now its gone.
