Rebuild Carbs - BS38's on a '77 KZ750
15 Jul 2011 18:24 #463037 by Tested
I am looking to rebuild my carbs this weekend. I ordered two rebuild kits from www.Z1enterprises.com
Is there a definitive thread or can someone point me in the right direction.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
16 Jul 2011 02:15 #463117 by bountyhunter
Replied by bountyhunter on topic Rebuild Carbs - BS38's on a '77 KZ750
I have done it and remember the caveats:
1) Both main and pilot jets are in the bowls. You need to make a screwdriver to fit the slot or you will destroy the jet. Get a flatblade with proper blade thickness and grind width to match jet. Keep as dedicated tool.
2) becareful taking off the diaphragms, they tear easily. Inspect looking into light for slits.
3) If you have original mounts, they probably leak.
I would take the carbs off the bike for good cleaning. Bench sync them before remounting.
Set fuel levels with clear tube before adjusting anything else because fuel levels screws up other things.
Be VERY careful tightening the bowl screws, they strip easily.
16 Jul 2011 12:09 #463149 by Tested
Replied by Tested on topic Rebuild Carbs - BS38's on a '77 KZ750
What does it take to bench sync them?
Hell what does that mean?
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
16 Jul 2011 12:25 #463150 by Chaotic Reason
Replied by Chaotic Reason on topic Rebuild Carbs - BS38's on a '77 KZ750
The Filebase (top right hand corner) is your friend on here. It has a ton of great information. If you hover over Filebase, and then choose search, you can then type in the keywords, "bench sync". The second or third results are the ones you want. Step by step instructions with pictures! I would've just copied it on here, but the pictures don't come with it that way. :)
Michael
1980 KZ1000 shaft drive
The following user(s) said Thank You: Tested
17 Jul 2011 01:47 #463277 by Tested
Awesome. I was looking thru the rebuilt kit and there is a metal washer and a spring that I don't recall seeing in my carbs when I cleaned them. I thinking huh maybe a problem.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
18 Jul 2011 00:21 #463432 by Tested
Well I rebuilt them. Feel pretty good about it. Adjusted the tabs on the float up and got the thing stop leaking like a man with a hole shot in him.
The idle is doing pretty good but it runs like crap. Need to sync the carbs still, didn't have time or the hose.
I did put two in line fuel filters. The one on the left kinda pinches the fuel line so I will need to get a longer one.
This thing is costing me some cash and time but I feel like I am pretty close to getting it running well. Hopefully soon so I can start using it as my commuter.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
