Engine Pinging-81 1000LTD, jetting changes?
- Saggs
- Thank you received: 2829
- Saggs
- Saggs
- otakar
Saggs wrote: I just bought a completely stock 81 1000 LTD w/ 33k miles. I removed and thoroughly cleaned the carbs, set the float height, adj the valves, new plug wires and caps. I also did the 12v relay trick to power my coils w/ full battery voltage and that helped alot! I'm now getting some pinging when running more throttle up hills or pulling past 70mph in top gear. I was given the larger (127) mains and the adjustable needles that came with the "J" model that year. Any reccommendations on jetting changes I should make? This is my first day on your forum- Looks great!
First of all the "relay mod" is not necessary on these bikes. It may have some use on the older bikes. If you have pinging with ANY gas let alone premium, you have other problems. That bike should run fine on 87 octane with out any detonation. Do you have the right plugs in it? What position do you have the needles on and what is the # on the needles. Here in the US not even the police bikes came with the adjustable needles. Those were however available in Canada on almost all bikes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Saggs
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Saggs
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
Saggs wrote: ...stock 81 1000 LTD w/ 33k miles...set the float height...getting some pinging when running more throttle up hills or pulling past 70mph in top gear....
Does adding some choke reduce the pinging?
If not already done, would perform the clear tube test to assure float bowl fuel levels are within specs.
A too low fuel level may result in pinging due to lean mixture, even with otherwise perfect carbs and perfect fuel supply.
The optimal measured float height is whatever height results in the correct fuel level.
- Polar_Bus
- Thank you received: 7
"pinging" is ignition/combustion related. Your jetting really doesn't affect detonation. Just to be clear on your description of "pinging" you are talking about cylinder detonation correct ?
Bikes:
'84 GPz1100
'06 HD Fatboy
