- Thank you received: 2
Cant seem to get pilot screw o-ring and washer out
- ravenz07
12 Jul 2011 14:33 #462467
by ravenz07
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
Cant seem to get pilot screw o-ring and washer out was created by ravenz07
Anyone know of a good way to get these things out?
For my Mikunis from the KZP
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Jul 2011 22:03 #462546
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Cant seem to get pilot screw o-ring and washer out
look for some small hooked tools like dental equipment that mechanics use, then you're set.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
12 Jul 2011 23:39 #462577
by Patton
Replied by Patton on topic Cant seem to get pilot screw o-ring and washer out
Been enjoying this set for several years
www.z1enterprises.com/Hook-and-Pick-Set-1469.aspx
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
12 Jul 2011 23:39 #462578
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic Cant seem to get pilot screw o-ring and washer out
I used a small paper clip. Straighten out the curves, and then use pliers to bend the last 1/16" of the wire end to about a 90 degree angle. Carefully fish this down into the ring and "O" ring, and gently pull them out. I was trying to remove what was not there one time, and had trouble seeing just what was in the hole. Later found the parts on the floor. Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
- Thank you received: 23
13 Jul 2011 00:19 #462582
by seanbarney41
Replied by seanbarney41 on topic Cant seem to get pilot screw o-ring and washer out
yep, you may discover that they are no longer in there because the po blasted them into the void with a 120psi air nozzle blast:pinch:
