kz1000 bs34 carb
- kawastrtfgtr
12 Jul 2011 06:36 #462405
by kawastrtfgtr
kz1000 bs34 carb was created by kawastrtfgtr
when i started engine everyday it works good (4 cylinders)but it waits more than 24 hours when i started engine it works 3cylinders than few minutes later 4.of cylinder comes ...
does gas waiting more than 1 day inside the carburetor is it clog some holes or does anyone knows what happens?
- roy-b-boy-b
- Thank you received: 103
12 Jul 2011 10:10 #462428
by roy-b-boy-b
Replied by roy-b-boy-b on topic kz1000 bs34 carb
Which cylinder goes dead?
Just a guess but I would think that gas in going into that cylinder while the bike sits. Roy
- kawastrtfgtr
13 Jul 2011 04:55 #462605
by kawastrtfgtr
Replied by kawastrtfgtr on topic kz1000 bs34 carb
#4 of the cylinders, if gas going to cylinder is the spark plug getting wet? it is dry and its burning color is grey.
it sits more than 1 day it starts 3 cylinders i am waiting few minutes when it works its not coming #4 then i ride it by 3 clinders;i turn the thotle near maximum position and turn thotle close number 4 comes litle bit, few minutes riding as that #4 comes...
- Goalieguy35
- JJ
- Thank you received: 2
13 Jul 2011 20:14 #462712
by Goalieguy35
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
Replied by Goalieguy35 on topic kz1000 bs34 carb
Check compression. I had a valve guide pull slightly from the head and ran only when got hot. Really weird situation but you never know, it wouldnt fire till engine got hott
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- kawastrtfgtr
14 Jul 2011 03:56 #462778
by kawastrtfgtr
when i parked it eveninig its ok and the other day morning its okey too; all night its cooling, i want to start at morning engine cooler than same day evening- its sitting hour problem...but why?
