Jet needle improves acceleration.
- spudbudy
- Kick it like you mean it
Re: Jet needle improves acceleration.
26 Apr 2018 04:20
140 is way too big I would not go over 120\125 max. Pods are extremely hard to tune. Good luck. If you want better performance go with bigger carbs
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles.
and climbing daily.
The following user(s) said Thank You: Tesk
- Tesk
26 Apr 2018 06:35spudbudy wrote: 140 is way too big I would not go over 120\125 max. Pods are extremely hard to tune. Good luck. If you want better performance go with bigger carbs
What do you mean by bigger carbs? Is there a modification I dont know about lol? What if I want the less problem possible
26 Apr 2018 06:49
If you really want the fewest problems, put the factory intake system (air box, filter, and all) back on. If you have a 750 twin with BS34 carbs, they are notoriously difficult to tune for individual filters, and you will likely loose a little performance along the way.
Unless you are going to add high compression pistons, ported head, high performance cams and bigger carbs, there really is no point in individual filters. The stock setup flows as much as the stock engine needs.
- Tesk
26 Apr 2018 07:03
Actually I have a kz 750 ltd 1982, heihin carburetors. But Im so fucking confused because of leaking fuel to the airbox. And when I open the carburetor the float valves mooves freely, have already cleaned EVERY part of the carburetor, the only thing I think it is, is a dirty diaphram inside the petcock because of a dirty gas tank.
- krankins
29 Jun 2020 00:11
I tried poking around the forum to get a feel for thoughts on raising the jet needle. If in fact the needle jet were worn I would assume a rich condition. As stated my issue was with a lean quarter to 3/4 throttle.
- krankins
18 Aug 2020 02:44 - 18 Aug 2020 06:58
guys i have a issue can you please help me out ?
NOTICE I deleted your attached link It came up corrupted . What is it to.
Dave Street Fighter LTD Admin
Last edit: 18 Aug 2020 06:58 by Street Fighter LTD.
- sparkyzappa
08 Sep 2020 18:48 - 08 Sep 2020 19:16
Is it possible to wheelie a kz1000? Just asking cuz Ive never even tried? Im having the mid range blues also (KZ1000 ltd 1977 pods and 4 into one's all other engine specs good) I raised the needle tonight testing it tomorrow. Adjusting fuel screw out one turn I got max rpm on number 4, but do I set them all the same or do I adjust for max rpm no matter where they end up on the rest?
Last edit: 08 Sep 2020 19:16 by sparkyzappa.
- zed1015
09 Sep 2020 00:23You want these for the hesitation on your 77 1000.sparkyzappa wrote: Is it possible to wheelie a kz1000? Just asking cuz Ive never even tried? Im having the mid range blues also (KZ1000 ltd 1977 pods and 4 into one's all other engine specs good) I raised the needle tonight testing it tomorrow. Adjusting fuel screw out one turn I got max rpm on number 4, but do I set them all the same or do I adjust for max rpm no matter where they end up on the rest?
www.kzrider.com/forum/23-for-sale/611992...-round-slide-mikunis
go a couple of sizes up on the mains and put all other settings back to stock..
- Ltd fan
27 Sep 2020 00:20 - 27 Sep 2020 00:23
Tesk .....Same bike same problem , mate (Mikuni carbs) . see my post on PETCOCKPROBLEMS" CARBURETTOR forum on here . However having dealt with THAT , I went out yesterday to find No 2 carb flooding . in traffic and at lights queues and roundabouts etc fuel flooding all over . managed to get home just before end of tank reserve.
Stripped carbs and all looked behaved perfectly . Once throbbing temples have calmed and Ive drunk some rum ..... I'll let ya know .....
Last edit: 27 Sep 2020 00:23 by Ltd fan.
- gd4now
- Denco where did you go?
27 Sep 2020 10:51
I know this is an old thread and I am way late to add much, but there was much talk about moving the needle up or down. I wanted to add the from a Mikuni carb manual which has a table showing the increase or decrease in fuel flow when moving the needle.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- daveo
15 Jul 2021 09:09This is incredibly helpful information.I know this is an old thread and I am way late to add much, but there was much talk about moving the needle up or down. I wanted to add the from a Mikuni carb manual which has a table showing the increase or decrease in fuel flow when moving the needle.
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
- Fabrique au Japon
26 Mar 2022 00:56
For having stock pilots.....what altitude are you at or riding in?
-Sept 76 KZT00A
Diamond Sky Blue faded Brown
-57 VW
Dual 40mm DRLA DelloRTo
-57 VW
