- Thank you received: 2829
1981 KZ 650H1 CSR Pods or box air filter?
11 Jul 2011 15:14 - 11 Jul 2011 15:52 #462271
by 650ed
Replied by 650ed on topic 1981 KZ 650H1 CSR Pods or box air filter?
"fairly low-end bikes back in '81"
Just so ya know, when the KZ650 was introduced (airbox & all) in 1976 it was, in the hands of a pro, the 3rd fastest 1/4 mile bike in production behind the big Kawasaki and the Suzuki 750. Fairly low-end in terms of price compared to the British bikes, Harleys, etc. but not low end in performance. Compared to modern bikes it's no rocket, but in its day it commanded respect. If you get yours performing up to stock specs I believe you'll be pleasantly surprised. Ed
You might find this original road test interesting:
www.kz650.info/articles/documents/KZ650%...World%20Roadtest.pdf
1977 KZ650 World Records (they set a bunch more in later years)
Attachment WORLDRECORDS.jpg not found
Last edit: 11 Jul 2011 15:52 by 650ed.
- matt650csr
11 Jul 2011 19:51 #462314
by matt650csr
Replied by matt650csr on topic 1981 KZ 650H1 CSR Pods or box air filter?
I suppose you are right about that. They aren't low-end on performance and aren't bad bikes. I guess I should also clarify what my goal with this bike is... I want it to resemble a cruiser, run smooth and have whatever power it is capable of. I am not trying to get some performance street bike out of it... I have strong (mostly negative opinions) on street bikes, crotch rockets and (most) of the people that ride them. I just want a nice bike to ride around on that I can mess with and chop up a bit... which I feel a lot of people on here will hate me for since this is a KZ site people seem (understandably so) really focused on these bikes as they are, stock and OEM and all that haha... but yeah I doubt I will end up going with the pods. I will probably just get a nice K&N in the box. I am having a hard enough time getting the carbs apart to clean them. Are the screws on these bikes notoriously crappy? Because almost every screw holding the middle two carbs onto the bracket won't turn and just strips out the metal til I have a lovely circle I have to drill out.
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
11 Jul 2011 21:59 #462347
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic 1981 KZ 650H1 CSR Pods or box air filter?
Nobody going to hate you unless you were going to make a chopper out of a Z1. Then maybe a few would then come a huntin' you. But we will always be giving you opinions whether asked for or not. Not sure if we all expect you to heed them tho. As for the screws get some PB Blaster and soak everything in sight. Or at least the day before you are going to be removing something. Also remember antiseize for galling bolts.
- matt650csr
11 Jul 2011 22:04 #462350
by matt650csr
Alright so no witch hunts for me then! Thanks for the PB Blaster tip, I wish I would have thought of that sooner before I drilled out this one little SOB of a screw! It's an easily replacaeable one at least...
- Thank you received: 1656
12 Jul 2011 08:23 - 15 Feb 2013 11:18 #462409
by martin_csr
Last edit: 15 Feb 2013 11:18 by martin_csr.
12 Jul 2011 08:33 #462412
by 650ed
I'm a big Kroil fan. It really works! Ed
12 Jul 2011 08:40 - 22 Jan 2013 03:38 #462414
by martin_csr
Last edit: 22 Jan 2013 03:38 by martin_csr.
12 Jul 2011 08:54 #462415
by 650ed
Kroil can be ordered from various places. One is Kano Labs (the Kroil manufacturer), another is Midway. I bought the Kroil 1/2 pint (8 oz.) can - $8.00 ea. from Kano Labs (it's about half way down the page inthe 1st link below) and I believe the 1 can will last my lifetime. I haven't tried the aerosol, but the regular 1/2 pint can has a built in spout that let's you put the stuff right of the nut/threads.
secure.concentric.com/kanolabs.com/orders/order.shtml
www.midwayusa.com/viewproduct/?productnu...CompListing-_-137203
- Proxy
12 Jul 2011 09:14 #462419
by Proxy
Geese I like PB Blaster. Hafta try Kroil if I can find some. I like WD as a cleaner.
- Ryan1288
07 Aug 2019 13:10 #808877
by Ryan1288
Replied by Ryan1288 on topic 1981 KZ 650H1 CSR Pods or box air filter?
Does anyone have an airbox for a 1981 csr for sale? I bought a bike that already had pods and it runs like shit and I wanna go back to the airbox but ebay only has a few for sale and they are all trashed or more than 100$
Thanks
Ryan
Thanks
Ryan
07 Aug 2019 14:24 - 09 Aug 2019 05:13 #808883
by martin_csr
Replied by martin_csr on topic 1981 KZ 650H1 CSR Pods or box air filter?
No eBay APP ID and/or Cert ID defined in Kunena configurationYou can use the airbox from an 81-83 KZ650-CSR. The 650-CSR airbox is embossed with KZ750E/H, so you can use one from a KZ750E or KZ750H Ltd. Some 750-4 airboxes have holes in the bottom where tubing grommets are supposed to be fitted, but you can just plug those holes.
EB search = KZ750 airbox. A number of airboxes are listed. other searches may yield more results.
This one appears to be dirty, but there isn't any obvious damage. I always ask questions when unsure of the condition.
Last edit: 09 Aug 2019 05:13 by martin_csr.
07 Aug 2019 14:35 - 09 Aug 2019 05:14 #808884
by martin_csr
EB search = KZ750 air cleaner.
Item #183616232416. >> has model embossing in 2nd pic. The 650-CSR airbox is the same.
note: the 81 650-CSR ducts for VM24 carburetors are unique to the model, but they are NLA. 750-4 ducts can be used, but you have to add donuts fashioned from radiator hose to make up the difference where they connect to the carburetors. use good ss band clamps.
Last edit: 09 Aug 2019 05:14 by martin_csr.
The following user(s) said Thank You: Ryan1288
