carb problem, i think.
03 Jul 2011 00:23 #460698 by tos601
carb problem, i think. was created by tos601
I have a 1980 kz550 and the fuel is not leaving the bottom of the carbs to the engine. the carb has been reubilt, and the floats do not stick. I know it turns over and fires with carb cleaner, and I know the fuel gets down to the bowl. Can anyone help?
  • TeK9iNe
  • What did you do!?!
03 Jul 2011 12:00 #460745 by TeK9iNe
Replied by TeK9iNe on topic carb problem, i think.
The fuel level must be checked and made to be very accurate to spec.
Make sure that your mixture/air screws are not turned in all the way by accident.
Increase the main idle screw.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
05 Jul 2011 13:35 #461144 by GPZPDX
Replied by GPZPDX on topic carb problem, i think.
Your carbs aren't as clean as you think
Completely disassemble them and clean every passage - better yet, dunk them in cleaner bucket, like Berrymans
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
