- Thank you received: 2098
Carb noise @ idle
09 Jul 2011 06:47 #461824
by Patton
Replied by Patton on topic Carb noise @ idle
Perhaps the pilot jet itself is partially clogged.
Could swap the pilot jet with another carb and test run to determine whether the excessively rich condition follows the pilot jet.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
10 Jul 2011 01:49 #461973
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Carb noise @ idle
If the mixture screw makes no difference - the circuit is plugged. Whether you would like to believe it or not - its either not getting any fuel, or the sync is so bad that that slide is nearly closed completely. Or you have a significant air leak.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
