KZ440- Carb Float banging
27 Jun 2011 19:09 #459778 by gaillarry
KZ440- Carb Float banging was created by gaillarry
Installed new carb boots on my son's 82 KZ440. Started the bike up and the left carb is making a banging noise. I can feel the float bowl cover and the float is banging inside the carb as the bike idles!
Going to remove the float bowl cover but never heard of a float banging inside the carb??
1977 KZ1000
1985 Gpz750
  • KZ_Rage
  • Kentucky Bourbon Barrel Ale
27 Jun 2011 19:13 #459781 by KZ_Rage
Replied by KZ_Rage on topic KZ440- Carb Float banging
I'd guess it is the CV carb's vacuum slide pulsing with the engine and not the float, I can't see the float moving that fast nor does it have much mass so I really doubt it but then again strange things can happen!
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • KZ_Rage
27 Jun 2011 19:16 - 27 Jun 2011 19:16 #459783 by KZ_Rage
A little visual.. #16126
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
Last edit: 27 Jun 2011 19:16 by KZ_Rage.
27 Jun 2011 20:52 #459809 by gaillarry
Replied by gaillarry on topic KZ440- Carb Float banging
Removed the float bowl and everthing inside looks ok. What would make the vaccum piston pulse?
1977 KZ1000
1985 Gpz750
  • KZ_Rage
27 Jun 2011 21:28 #459825 by KZ_Rage
Not too sure about the cause, but you should probably check to be sure the diaphragm isn't damaged and that the spring is in there. Another thing would be if it were way out of sync possibly, never had one that far out but I guess that could attribute to the cause.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
