75 kz400 carb question
- Scooterbob
08 May 2006 15:56
I have a 1975 kz 400 with the stock kehin carbs on it and it runs really lean with the pods and drag pipes with slip in baffles in the pipes. I was wondering if anyone else has done these mods and what jest you ended up ruinning. I can buy them but will have to buy a 5 pack and don't want to spend 30.00 for 5 jets the same size that won't cure my problem... Hope someone can help with this matter ... thanks, Scott.
- KitNYC
Re: 75 kz400 carb question
08 May 2006 16:07
Can't tell you what sizes to try; I'd be interested in knowing as well. What I can tell you is where to get 'em for $3.25 each:
Cycle Recycle
Good luck!
-Kit
Good luck!
-Kit
- Scooterbob
08 May 2006 16:17Please Log in or Create an account to join the conversation.
