- Thank you received: 4
Dial Fuel Inlet Swivels
- Sactown900
25 Jun 2011 19:15 #459329
by Sactown900
Dial Fuel Inlet Swivels was created by Sactown900
I was going to try and start this 19 year stored bike this weekend. My 26 year old son and I thought we could do this project together. It's on hold for now. Several members told me the OR had float b owl drain lines in the wrong place (A HUGE THANK YOU)
If the inlet between carbs 3 and 4 began leaking right away, is this a a carb rebuild issue?
Thanks.
Thanks.
- MFolks
- Thank you received: 540
25 Jun 2011 19:27 #459332
by MFolks
Replied by MFolks on topic Dial Fuel Inlet Swivels
Probably the "O" ring seals have dried up causing the leak(s).
Try these websites for parts:
Carb Parts
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.oldbikebarn.com/Motorcycle_Parts/Carb-Rebuild-Kit
www.cycleorings.com/
Carb Parts
www.nrp-carbs.com
www.jetsrus.com
The following user(s) said Thank You: Sactown900
- Kawboy74
- Thank you received: 52
27 Jun 2011 23:55 #459858
by Kawboy74
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
Replied by Kawboy74 on topic Dial Fuel Inlet Swivels
Those tubes coming out of the fuel bowls are overflows and should be looped down in front of the swingarm. The tubes coming out of the inlet manifolds should have bullet-shaped plugs over them and be in non-cracked condition.
Good luck. David
Good luck. David
- Thank you received: 2098
28 Jun 2011 00:56 #459879
by Patton
When re-exposed to gasoline, the "fuel pipes" will sometimes quit leaking.
Replied by Patton on topic Dial Fuel Inlet Swivels
Sactown900 wrote: ...19 year stored ...inlet between carbs 3 and 4 began leaking right away, is this a a carb rebuild issue?....
- Sactown900
28 Jun 2011 01:18 #459885
by Sactown900
Replied by Sactown900 on topic Dial Fuel Inlet Swivels
Is this page from Factory Service Manuel? I just bought one on EBay.
We'll fix our float bowl vent line issues this weekend and test that theory. With 95k on the bike (and stored 20 years) my son and I may tear it down and paint it, while the carbs and engine are getting a rebuild.
Thanks
Thanks
28 Jun 2011 01:38 #459892
by Patton
And here with some added pics:
Yes, FSM for Z1~KZ900.Sactown900 wrote: Is this page from Factory Service Manuel....
