Carb sync steps
  • ravenz07
  • ravenz07's Avatar Topic Author
Carb sync steps
24 Jun 2011 00:01
#459058
I have a manometer, and good to go on the sync. Which order do I sync the carbs?
Currently, the carb starts but it seems that it wants to die and I am getting a lot of grey smoke.
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
  • bigkzfan
  • bigkzfan's Avatar
  • if grandpa had tits he"d be grandma, if
Re: Carb sync steps
24 Jun 2011 10:34
#459102
if its a set cv34s there are 3 adjustment points left, right and middle. adjust left adjustment screw until carbs one and two are pulling the same amount withing 2hgs..tighten the nut make sure it stays the same which can be very tricky.then go to the far right and adjust carbs 3 and 4 the same way..once you have carbs 1 and 2 and carbs 3 and 4 set together go to the middle adjustment point and balance all 4 together..it can be a pain but be patient, and remember to adjust after it has warmed up and put a fan in front of the engine
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
  • bigkzfan
  • bigkzfan's Avatar
Re: Carb sync steps
24 Jun 2011 10:37
#459103
blip the throttle after you get them set and make sure you are still even..may have to tweak some
  • ravenz07
Re: Carb sync steps
24 Jun 2011 15:39
#459159
The carbs are Keihin. Is it the same process?
  • bigkzfan
  • bigkzfan's Avatar
Re: Carb sync steps
24 Jun 2011 17:11
#459173
o i know nothing about them type at all.. just the mikunis
