CARBS DRIVING ME CRAZY
18 Jun 2011 15:44 #458040 by 79kz1000
CARBS DRIVING ME CRAZY was created by 79kz1000
MY BIKE WAS RUNNING FINE THEN ONE DAY IT STARTED LEAKING GAS FROM THE OVERFLOW. SO I BOUGHT CARB KITS AND PUT THEM IN AND NOW THE BIKE WOULDNT START UNLESS I USE STARTING FLUID AND IT IDLES CRAZY. IT WILL IDLE SMOOTH AT 1000RPMS THEN WHEN I REV IT IT WILL STAY AT 2000RPMS AND THE SLIDES ARE CLOSED.....THEN WILL AVENTUALLY GO BACK DOWN. IT ALSO POPS SOMETIMES AND RUNS LIKE CRAP DOWN LOW. I TURNED THE MIXTURE SCREW 2 TURNS OUT WHICH WAS WHERE THEY WHERE. COULD THE NEEDLES BE DIFFERENT? THANKS FOR ANY HELP. ITS ON A KZ1000 HERE IS A PIC OF THE CARBS.
18 Jun 2011 16:02 #458044 by 650ed
Replied by 650ed on topic CARBS DRIVING ME CRAZY
Have you checked the carb holders for vacuum leaks?
18 Jun 2011 17:06 #458054 by revs KZ550
Replied by revs KZ550 on topic CARBS DRIVING ME CRAZY
You didn't mention anything about syncronizing the carbs. Have you done that since putting in the kits? That'll make a big difference. Make sure the small jets are really clean, if they're not, it'll kill your power down low. If neither of these, I'd check your vacuum hoses, as mentioned above.
- Revs
18 Jun 2011 17:18 #458057 by 79kz1000
Replied by 79kz1000 on topic CARBS DRIVING ME CRAZY
i think it would be a vacuum issue or the air/fuel miture screw. i never touched the slides but i might check that if i cant figure it out
27 Jun 2011 10:40 #459653 by LewisKZ
Replied by LewisKZ on topic CARBS DRIVING ME CRAZY
What do you think caused/fixed the gas leak in the first place?
1981 KZ440 LTD D2
27 Jun 2011 11:36 #459660 by 79kz1000
i beleive it was the needle and seat. i have replace the air mixture screws with the old one and problem has seemed to go away. i guess thats what happens when you buy a cheaper carb kit.
27 Jun 2011 14:03 #459698 by LewisKZ
Yeah, I get that leak on random occasions and it always seems to be the float/needle. If i bang on the bowl with something it usually gets it back in place. I swear i blame modern gas with the 10% ethanol cut. These carbs have such issues because they simply werent made for this sort of gas.
1981 KZ440 LTD D2
