kz1000j carb problem
  • kawastrtfgtr
  • Topic Author
16 Jun 2011 15:16 #457623 by kawastrtfgtr
kz1000j carb problem was created by kawastrtfgtr
i rebuilt the engine oversize with kz1100 pistons,and aftermarket air filters-carbs are stock.jets are stock 37.5-127.5 works good runs good.bike accelerating rpm comes 5000-5500 its caughing and rpm gauge dont want to see up rpms.
its my bike problem; does anyone lives like that problem to his motorcycle and solves it?
  • kawastrtfgtr
  • Topic Author
17 Jun 2011 14:56 #457794 by kawastrtfgtr
Replied by kawastrtfgtr on topic kz1000j carb problem
no idea anyone????
17 Jun 2011 18:36 #457835 by Patton
Replied by Patton on topic kz1000j carb problem
kawastrtfgtr wrote: i rebuilt the engine oversize with kz1100 pistons,and aftermarket air filters-carbs are stock.jets are stock 37.5-127.5 works good runs good.bike accelerating rpm comes 5000-5500 its caughing and rpm gauge dont want to see up rpms.
:unsure: Runs good but won't exceed 5500 rpm?
  • kawastrtfgtr
  • Topic Author
18 Jun 2011 17:00 #458053 by kawastrtfgtr
its exceed 5500rpm but its caughing starts at 5500rpm; i change fuel level high position, not the original level and it starts to caugh 6250rmp and up caughing...
18 Jun 2011 18:13 #458065 by otakar
Replied by otakar on topic kz1000j carb problem
Go Three sizes larger on the main jets.(135)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
The following user(s) said Thank You: kawastrtfgtr
  • TeK9iNe
  • What did you do!?!
18 Jun 2011 19:24 #458072 by TeK9iNe
Replied by TeK9iNe on topic kz1000j carb problem
otakar wrote: Go Three sizes larger on the main jets.(135)
Agreed.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kawastrtfgtr
  • Topic Author
19 Jun 2011 14:30 #458199 by kawastrtfgtr
main 140-pilot 40 , how it changes performance- thotle respons?
  • TeK9iNe
19 Jun 2011 22:38 #458251 by TeK9iNe
kawastrtfgtr wrote: main 140-pilot 40 , how it changes performance- thotle respons?
You'll have to see. It depends on your engine and altitude.
Might be a little too much. These engines are like to produce power slightly leaner than general, and happily do it thier whole lives.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kawastrtfgtr
  • Topic Author
21 Jun 2011 10:13 - 21 Jun 2011 10:20 #458509 by kawastrtfgtr
what are the jets sizes in stage3 jet kit in>? and i found two types of jet kits which is prefered by kz riders?
does it solves my bike problem 5900 up rpms exhaust cracking when accelerating?
Last edit: 21 Jun 2011 10:20 by kawastrtfgtr.
21 Jun 2011 10:35 - 21 Jun 2011 10:37 #458513 by otakar
The dynojet stage kits are complete different jets. The numbering system is not the same. With Mikuni the # is the Flow of the jet in cc/min, Dynojet is the size of the hole. There is no reliable liniar correlation between the two The Dynojet needles are un-anodized and will last a very short time because they will ware out. DONT mess with the pilot jet. My bike is an 1150 with .420 cams and a head that flows way over 100cfm and I run stock pilots and 142.5 mains. mine is way too rich. Popping exhaust during acceleration denotes a rich situation.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Jun 2011 10:37 by otakar.
  • kawastrtfgtr
  • Topic Author
21 Jun 2011 11:12 - 21 Jun 2011 11:23 #458521 by kawastrtfgtr
:huh: 135 mains ok? or something else? spark plugs are grey and air screws more than 2-1/2 open?
Last edit: 21 Jun 2011 11:23 by kawastrtfgtr.
