- Thank you received: 16
29mm smoothbore idle screw O-ring ?????
- mtkawboy
15 Jun 2011 21:19 #457500
by mtkawboy
29mm smoothbore idle screw O-ring ????? was created by mtkawboy
Does anyone know if the o-rings in the cycleorings.com VM will work on the 29 mm smoothbores idle mixture screws ? The kits are for VM's on Suzukis. If not does anyone know where I can buy a set ?
- Thank you received: 2098
15 Jun 2011 21:53 #457509
by Patton
Replied by Patton on topic 29mm smoothbore idle screw O-ring ?????
- mtkawboy
16 Jun 2011 13:57 #457613
by mtkawboy
Replied by mtkawboy on topic 29mm smoothbore idle screw O-ring ?????
Thank you, thats a big help. Do the smoothbores take the std Vm 26 & 28 mm main jets ?
- testarossa
- Thank you received: 82
16 Jun 2011 14:38 #457617
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic 29mm smoothbore idle screw O-ring ?????
Yes, the main jets are the same, but pilots are a different style.
2004 ZX-10R
Angola, IN
- mtkawboy
16 Jun 2011 17:33 #457632
by mtkawboy
Thanks, I made a Z1 Enterprises order today. Im going to drop from a 117.5 to a 115 because of the altitude here
16 Jun 2011 18:57 - 16 Jun 2011 19:01 #457643
by Patton
Main jet affects the fuel mixture only at wide open throttle (or nearly wot).
Smaller main jet will produce leaner fuel mixture only at wide open throttle (or nearly wot).
The needle clip position affects fuel mixture during mid-range throttle positions, regardless of main jet size.
Running too rich at normal cruising speed, say during first 1/4 throttle position, could be caused by several different things, such as too high fuel level, clogged pilot air jet, dirty or blocked air filter, etc.
The "normal" main jet size is 120.
mtkawboy wrote: Thanks, I made a Z1 Enterprises order today. Im going to drop from a 117.5 to a 115 because of the altitude here
Last edit: 16 Jun 2011 19:01 by Patton.
16 Jun 2011 19:10 #457646
by Patton
The BS30-97 air jet is easy to overlook when cleaning a smoothbore carb, because it's so small and inconspicuous (unless known about).
An imperfectly clean BS30-97 air jet may alone cause an excessively rich mixture during the first 1/4 throttle position, regardless of an otherwise perfect carb.
- mtkawboy
17 Jun 2011 16:16 #457815
by mtkawboy
I had a brown out on that last post, Im dropping the 17.5 pilots to 15s. I have to chek where the needle clips are unless I can find where I wrote it down. Old age is a biatch ! I did throughly clean the air jets, but thanks anyway. The pilot jets were just clogged from sitting too long. Too many bikes !
