1985 GPZ 750 Carb Dilemna
  • peachc
  • peachc's Avatar Topic Author
15 Jun 2011 20:27
#457487
Well, I finally got back into picking up another bike to work on and have ended up with carb fun land. The stock carbs on the GPZ 750 were installed with K&N Filters and Vance and Hince exhaust. I've rebuilt the carbs, cleaned every knock and cranny, got them running good at idle and throttle under no load. Now heres the kicker (9 bikes, never had this one), the bike once under load acts like someone is using a dropper to feed it gas. It just has no power and when I choke it, it gets the power back. Knowing this, obviously running extremely lean, but with the pilot screws 4 turns out, 125 mains, not too sure where to go next. Any insight will be greatly appreciated, as I can now break down carbs in under 30 mins now...
  • mtkawboy
  • mtkawboy's Avatar
Re: 1985 GPZ 750 Carb Dilemna
15 Jun 2011 21:20
#457501
Put the stock airbox back on
  • peachc
15 Jun 2011 21:27
#457502
Believe me, if that was an option, I would. I've even looked for one on ebay, but no dice. Personally not a big fan of pods...
  • peachc
16 Jun 2011 20:37
#457663
Anyone? :blink:
16 Jun 2011 21:13
#457673
If not already done, would assure o'rings on pilot adjuster screws are in good condition.
Also, would use strobe-type timing light to assure ignition timing is correct and is rapidly advancing and retarding when rpm is varied by blipping the throttle.
Good Fortune! :)
16 Jun 2011 21:15
#457674
Would also assure fuel level is within specs by performing the clear tube test on each carb.
Good Fortune!:)
