poping or back fire!
- uncle bear
14 Jun 2011 21:58 #457308
by uncle bear
poping or back fire! was created by uncle bear
I have a 76 KZ750 that sat for about two years. When I started it it was poping from the tail pipe. The tank had some rust so I cleand the tank and the carbs. I still have the same prob. I cleand the carbs agan but still runs the same. It starts without a problum but when it hits about 3k it pops alot. also when you let off the gas. Any suggestions.
- bountyhunter
- Thank you received: 337
15 Jun 2011 02:13 #457358
by bountyhunter
- Chaotic Reason
- Thank you received: 15
15 Jun 2011 14:53 - 15 Jun 2011 14:55 #457425
by Chaotic Reason
Michael
1980 KZ1000 shaft drive
Replied by Chaotic Reason on topic poping or back fire!
Mine's doing the same thing. I was thinking that the valves might not be sealing properly on mine? Do you hear it from the carb sometimes too? I was also thinking that I needed to do a major tune up to it. Change the plugs, plug wires, look at the timing and so on. Have you done that already? Notice any differences if so?
Michael
Last edit: 15 Jun 2011 14:55 by Chaotic Reason.
- uncle bear
15 Jun 2011 22:03 #457510
by uncle bear
Replied by uncle bear on topic poping or back fire!
Yes I have set the time,changed the points and plugs. I have also spraid carb cleaner around the out side. I think I may try a new set of carb gaskets. It could be a vacume leak. I will try to check the rubber parts better. Thanks
