KZ 1000 LTD " NIght Mare "
  • dragbikewillie
  • Topic Author
14 Jun 2011 18:41 - 14 Jun 2011 18:43 #457281 by dragbikewillie
KZ 1000 LTD " NIght Mare " was created by dragbikewillie
1980 KZ 1000 LTD ..Carbs are 120 / 2 pumpers..5cn29 needles ,2.0 slides, 20 pj's ,screws out 1 turn , 132.5 mj's..Elev @
6500 - 7500 above sea level..engine is stock with exception of K&N pods and Kerker pipe w/comp baffle.
I had no idea what the stock jetting was cause someone else had been in these carbs...Well, I have jetted on this thing till I'm blue in the face and it's still lean..could the spacers on the needle be in the wrong position ?...I put them back like I found them , thick on top and thin on bottom..Can not find any pic's to check if this is right!....Thanks anyone !:sick:
Last edit: 14 Jun 2011 18:43 by dragbikewillie.
14 Jun 2011 19:12 #457286 by MFolks
Replied by MFolks on topic KZ 1000 LTD " NIght Mare "
If no luck here: try www.wgcarbs.com If he has time, he might help you.
14 Jun 2011 19:20 #457288 by racer54
Replied by racer54 on topic KZ 1000 LTD " NIght Mare "
120/2 pumpers? What sort of carbs are those? Never heard of them called that. Otherwise, from the other information, sounds to me like you are way rich! At that elevation, the air is thinner then sea level so you should need leaner jets then stock. Beings there isn't as much oxygen you don't need as much fuel. If I had a better idea what carbs those are and the size, it would be easier to figure out.
  • dragbikewillie
  • Topic Author
14 Jun 2011 20:36 #457297 by dragbikewillie
Replied by dragbikewillie on topic KZ 1000 LTD " NIght Mare "
Thanks racer54 for your in put...Seems no matter how much fuel is going in it would show on the plugs...plugs don't lie !...I'm thinking , for a stock engine this thing sure is taking a lot!..lol..These carbs have an accelerator pump on them to delete a stumble upon acceleration..supposedly they had a lean mixture from the factory..I guess one of Kawasaki's better Ideas!..Ha !
14 Jun 2011 21:35 - 14 Jun 2011 21:40 #457303 by cavanaughracing
Replied by cavanaughracing on topic KZ 1000 LTD " NIght Mare "
dragbikewillie wrote: 1980 KZ 1000 LTD ..Carbs are 120 / 2 pumpers..5cn29 needles ,2.0 slides, 20 pj's ,screws out 1 turn , 132.5 mj's..Elev @
Those needles are fixed position needles [no grooves to adjust the clip] and that's precisely where your lean problem is coming from. I've seen this several times over the years with those particular carbs.
Those carbs were ultra lean jetted in the midrange. O-1 needle jets. You want needles from pretty much any of the earlier models that were adjustable. A good all around needle would be 5DL31. That's the same needles that came in the 29 smoothbore Mikuni's and also the 77 LTD1000 OEM 26mm carbs but with O-6 & O-5 needle jets, respectively.
You can keep putting main jet to it and it won't cure the problem because the fuel restriction is downstream of the main jet ;)
For now, shim your needles up with 2mm worth of washers. Make sure the thin plastic washer is on the bottom and the thick one on the top. Also make sure the spring is in place under the needle. The plugs should come around. NOTE, the fuel doesn't color up a plug as easily these days also...
Forget the electrode insulator for color. Look at the base ring of the plug. The very bottom of the threads that's exposed to the chamber. Watch for that to color up. Light grey all the way around is ideal but you may only get coloring on portions of it early on.
Larry C
Last edit: 14 Jun 2011 21:40 by cavanaughracing.
  • dragbikewillie
  • Topic Author
14 Jun 2011 21:56 - 14 Jun 2011 22:07 #457307 by dragbikewillie
Thanks Larry !...Glad to know I got the spacers right any way!..lol..Just out of curiosity would you know what the stock jetting is on these carbs?..BTW what do you think about my PJ & setting,even after I put in the shims?..I guess with this kind of pipe and pods it needs fuel huh?...Damn pump gas sure can mess things up!..lol..that needle you described will it make it crisper..Seems the more fuel I dump the more sluggish it gets!...This bike belongs to a customer and he's pretty anal about noise.
I had a 120 mj in before and at a steady 5000 rpm you could bearly hear the pipe crackel like it was to lean thats when I started adding more fuel ...Thanks for the info for sure!...I'm not much on these old carbs but I tell ya I'm sure getting a good learn'n !...lol
Bill
Last edit: 14 Jun 2011 22:07 by dragbikewillie. Reason: to ad more info
14 Jun 2011 22:38 #457313 by keith1
Replied by keith1 on topic KZ 1000 LTD " NIght Mare "
"The man knows his shit"......Listen and learn.......just my useless .02.....i don't come around much anymore, but i know excellent advice when i see it....
14 Jun 2011 23:20 - 14 Jun 2011 23:26 #457327 by cavanaughracing
dragbikewillie wrote: Thanks Larry !...Glad to know I got the spacers right any way!..lol..Just out of curiosity would you know what the stock jetting is on these carbs?..BTW what do you think about my PJ & setting,even after I put in the shims?..I guess with this kind of pipe and pods it needs fuel huh?...Damn pump gas sure can mess things up!..lol..that needle you described will it make it crisper..Seems the more fuel I dump the more sluggish it gets!...This bike belongs to a customer and he's pretty anal about noise.
Bill
Stock is 15 pilot and 102.5 main in a B4 LTD with those carbs. Slides are a 2.0 Do a design fuel level check on them if you haven't already. That really needs to be right to get jetting to fall into place and make sense. That's the check where you actually see the fuel level in the bowls. Float height doesn't mean much.
If it's popping on deceleration you can try a tad more fuel with the pilot fuel screws....say 1/4 turn richer to start. If you get to where you have to make the low speed too rich with the fuel screws to clean up the popping, then go to a 17.5 pilot and rework the fuel screws leaner.
Main will probably need at least a 120. A good ballpark setup would be this.
17.5 pilots [you can keep your 20's in for now and see how they work out..might like them]
Shim the needles up 2mm
125 Main Jet
1/2 turn out on pilot fuel screws
When you nail the needle clip position, you'll feel it get a lot more responsive when you blip the throttle from idle to 3000 RPM. If it's the least bit sluggish there, it will probably be lean when you ride it.
Another nice option is to pull the screens out of the airbox, put a clamp on K&N in place of the silencer tail section of the airbox. Put in 17.5 pilots and about a 110 main jet. But ultimately / unfortunately, you still have to keep grinding away till you nail what that particular engine with that particular pipe likes best ;) Plus....I'm sure the customer want's the pods because "they're better" :woohoo:
Keith :) How have you been? Good to hear from you again.....
Last edit: 14 Jun 2011 23:26 by cavanaughracing.
14 Jun 2011 23:28 - 15 Jun 2011 07:07 #457330 by keith1
edited
Last edit: 15 Jun 2011 07:07 by keith1. Reason: 'cause
14 Jun 2011 23:32 #457332 by keith1
larry,
i have been well...i will PM my GPZ issue that developed last weekend.....po,ed to say the least..........
  • dragbikewillie
  • Topic Author
14 Jun 2011 23:55 - 15 Jun 2011 00:05 #457339 by dragbikewillie
Thanks Larry! I'll go ahead and put the 120's back in with the shims..Also,it doesn't have an air box..it has the K&N pods..I did forget to tell you that I did set the fuel level at 3mm..I had read between 2-4mm and 3 was recommended..and also the slide height is set at 1mm..your opinion plz !..I did check the plugs again after what you told me and seems the anti seize covered the threads so I'm looking just b4 the threads which is almost a gold or very light tan color...You on the forum regularly?..Just in case I have another issue..Thanks again for all the info..
Last edit: 15 Jun 2011 00:05 by dragbikewillie. Reason: ad info
15 Jun 2011 07:43 #457374 by cavanaughracing
dragbikewillie wrote: Thanks Larry! I'll go ahead and put the 120's back in with the shims..Also,it doesn't have an air box..it has the K&N pods..I did forget to tell you that I did set the fuel level at 3mm..I had read between 2-4mm and 3 was recommended..and also the slide height is set at 1mm..your opinion plz !..I did check the plugs again after what you told me and seems the anti seize covered the threads so I'm looking just b4 the threads which is almost a gold or very light tan color...You on the forum regularly?..Just in case I have another issue..Thanks again for all the info..
I used to be....
I'll look today to see what needles I have. If I have 4 adjustable needles, I'll PM you. You can have them if I've got them. You can also find me here cavanaughracing.prophpbb.com/
