- Thank you received: 20
750 carb spacing
- nads.com
13 Jun 2011 14:50 #457015
by nads.com
750 carb spacing was created by nads.com
Will 750 cv34 carbs fit on a 900 head? I just located a pair and I'm chompin at the bit :evil:
- steell
- nads.com
14 Jun 2011 15:10 - 14 Jun 2011 15:23 #457260
by nads.com
Replied by nads.com on topic 750 carb spacing
I picked up a set of cv carbs off a 750ltd. They measure just short of 34mm in the back.
can I use these on my 1015cc? Are they any good compared to the gpz and all other 34mm cv's?
Do I have to change the needle? These carbs are like new, and I want to set them up but don't know what size jets to use to start with. HELP! Hope I didn't buy junk.
Otakar where are you!
I got good torque with the timing advanced but it linger at 9 something on the tack. I backed off the timing and now the motor is smoother and sails past 9,10 and heads for eleven. The power curve is smooth linear and just plain awesome.
I learned not to advance the timing to get the torque up, it cuts into the top end and chops it off short and blunt.
All you get is a good bump of torque at between 7 and 85000 and then it stops accelerating.
Now I notice the mph sailing by at higher speed and what I'm tellin you is that it's on.
The bike will get to 130 and sail past it quickly enough and now it's time for 34mm carbs to give me more grunt.
This thing is ready for any gpz once the 34's or on and tuned.
But I have the carbs on the bench and don't want them to stay there, with your help all I have to do is get up off the computer, set up install.
And look out .. There is no doubt this is one fast 1015cc.
Time to go beat it some more.
Love that sound of 9,10 grand! The pull! The acceleration. It all starts at 7 and from there you kinda lose track of time, space, distance.
Want you guys to know, byt helping me set up these 34's, your creating a monster.
Last edit: 14 Jun 2011 15:23 by nads.com.
- Thank you received: 797
14 Jun 2011 17:37 #457271
by 531blackbanshee
the front side of the carbs(the side that goes into the head)is where you need to measure to see what size they are.
not the back,:pinch: .
sorry to be of no help.
Replied by 531blackbanshee on topic 750 carb spacing
nads.com wrote: I picked up a set of cv carbs off a 750ltd. They measure just short of 34mm in the back.
- otakar
14 Jun 2011 19:35 - 14 Jun 2011 19:36 #457290
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 750 carb spacing
The spacing on KZ650/700/750/900/1000/1100 air cooled bikes, is all the same. You will only require the matching boots.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Jun 2011 19:36 by otakar.
