- Thank you received: 2
Throttle cables for '79 KZ650 B3
- seanof30306
09 Jun 2011 01:45 #456270
by seanof30306
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
Throttle cables for '79 KZ650 B3 was created by seanof30306
OK, so the cables on my @#$%^&!!! KZ650 are shot, so it's time for new ones.
The numbers on the existing cables are 12-140, and 12-141.
It has SuperBike bars on it, and the cables fit really well, so I was thhinking the factory cables might have been replaced with shorter ones, however, when I searched "12-140" throttle cable",I came across a thread where someone said his stock KZ650 had the same ones as mine. Are mine stock cables?
Also from my search, I learned 12-140 translates int PN 54012-140, and 12-141 translates into PN 54012-141, however, the cables listed for my bike on z1enterprises.com say they're: "Equivalent to OEM: 54012-081, 54012-087, 54012-149, 54012-150" www.z1enterprises.com/detail.aspx?ID=266
Searching 54012-081, I found this on ebay. cgi.ebay.com/ebaymotors/Kawasaki-Throttl...12-081-/170452349818
I've had GREAT service from z1enterprises.com, so i definitely prefer to buy from them whenever possible. Does anyone know what the difference between the cables is?
Thanks
Thanks
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Thank you received: 2829
09 Jun 2011 08:59 #456295
by 650ed
Replied by 650ed on topic Throttle cables for '79 KZ650 B3
- RonKZ650
- Thank you received: 241
09 Jun 2011 11:53 #456312
by RonKZ650
Replied by RonKZ650 on topic Throttle cables for '79 KZ650 B3
The cables at Z1 fit a KZ1000. No way to tell the difference without having the cables side by side to compare, but logic would indicate to me the 1000 cables would be longer than 650 cables from the factory, however the difference may be only 1/4" but no way to tell without comparing.
- Thank you received: 1656
09 Jun 2011 17:59 - 14 Feb 2013 11:36 #456354
by martin_csr
Last edit: 14 Feb 2013 11:36 by martin_csr.
