Pumper carbs
- dragbikewillie
- Thank you received: 2098
dragbikewillie wrote: Newbi here !..Need specs for 120 / 2 pumper carbs..Bike is a 1980 1000 ltd !..Thanks !
Hello, dragbikewilli, and WELCOME to KZr!
Are the carbs in question the same model carbs that originally came on the bike? And exactly which specs? Air box or pods? Oem exhaust or 4>1, and what baffle, if any?
Am thinking "specs" would typically include main jet, pilot jet, jet needle, and default pilot screw turns.
Anything else?
- dragbikewillie
Absent an FSM for reference, would "guess" service fuel level should be 2~4mm below bottom of carb.
- dragbikewillie
- cavanaughracing
- Banned
dragbikewillie wrote: Need float height & level and pumper rod adjustment..Seems I can't find this info anywhere and this particular bike I was told only had the pumper carb for 79-80!..uhgg just my luck!..Any info would appreciated !
Pump rod spec is in the B4 supplement manual. If it hasn't been fiddled with, don't touch it. They were good right from the factory. The 28 pumpers were the best carburetors Kawi ever put on a KZ1000.
Larry C.
cavanaughracing.com
- dragbikewillie
- C.T.
Here is a shot of what you are looking for. Good luck.
curtis
1979 KZ1000 L.T.D. B-3 Original Owner
2003 ZRX 1200R
1976 KZ900 A4 Project bike
Ione Ca.
- Thank you received: 1656
- wireman
- Thank you received: 299
- cavanaughracing
- Banned
dragbikewillie wrote: These carbs got jacked with from a shop that didn't know what they were doing and got'm all messed up so I'm having to fix a mess! I have a bike shop in Lubbock,Tx and from what I gather on these carbs I can understand why Kawasaki got away from them...I'm getting closer, just having a tuff time gathering info and so for now,I'm mostly going by the seat of my pants..Did find out that they will not take a large squirt from the pumper.Trying to save time by finding info!Making some head way and now if I can just find what the adjustment is on the pump rod I'll be done !...Ye-Ha!...Once I get this one done I have another bike just like it and then I think I will classify myself as a guru!."HA,ya right"!..lol.. Well, thanks for the help anyway!
I might have a rack that hasn't been jacked with. Holler if you need them.
Larry C.
cavanaughracing.com
