high revs
- Tony Taxi
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Remove the carbs, then the boots from the engine. Use a good (must say gasoline resistant!) gasket sealer like Permatex Motoseal - gray tube. You can use paper gasket from a local hardware store and cut your own, just greese each side of the gasket before installation.
Make sure everything is nice and clean before install.
Both sides - engine and airbox, must seal air tight to prevent the lean rev-up.
Try spraying some wd40 around the carb intakes, the carb tops, linkages, chokes, etc... anywhere that air could suck in, and watch for a change in exhaust color and an audible change in the engine/rpm.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2237
- TeK9iNe
TexasKZ wrote: Could also be a throttle cable problem. It (they) might need lube or it (they) might be frayed and need replacement. Might even possibly be glorp under the throttle tube (hand grip) causing poor return. Maybe all the above. Then there is the return spring.................
Yes, thats what I was trying to remember :laugh:
Could be so many things that will hang up the throttle cable. Look at the carbs when revving the bike, to see if the throttle returns all the way to stop when the revs hang.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Godfrey
- Thank you received: 10
1981 650CSR frame
1980 KZ750E engine
- 82KZ305Belt
- Thank you received: 36
- Tony Taxi
- Tony Taxi
- Robwolf
- It's ugly, but it moves!
'79 Kz400H1 'cafe' and '94 En500 Vulcan in swampy Florida.
