Mikun BS34 vs Keihin CV34
  • apbling
  • apbling's Avatar
Re: Mikun BS34 vs Keihin CV34
04 Jun 2011 09:35
#455316
Makes sense. Guess I've gotten lucky thus far, so no real gripes. :)
  • otakar
  • otakar's Avatar
04 Jun 2011 10:04 - 04 Jun 2011 10:08
#455322
The reason I HATE Dynojet kits is because they use a very soft Aluminum on the needles and completely neglect to Anodize therm. This leads to extremely accelerated needle ware and the carbs are after that un-adjustable. Dynojet than requires you to buy the entire kit again because they will not sell you just the needles. I wore out a set of DJ needles in less than one season. I now make my own kits and they work much better. I have Needles made to OE Mikuni specifications and tolerances. In 85% of the upgrades though, new needles are not even required. Not to mention the fact that with the DJ kits you now are using a completely different gauging system on the jets themselves. DJ claims how much better their jets flow but I find that to be BULLSHIT. I find the Mikuni jets to be much better and actually use them in Keihin carbs for that reason.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 04 Jun 2011 10:08 by otakar.
  • vonbagh
  • vonbagh's Avatar
04 Jun 2011 12:10
#455345
Shit, I tought those dynos are titanium jet needles, and needle jets might wear out easier because titanium might be too hard metal. There is also counterfeit jet kits, and on those kits needles are aluminium.
www.schiefermedia.com/PRESS/DYNO/PressRe...KnockOffJetKits2.pdf
Who knows?
Jos se ei tapa, niin se vituttaa.
  • ELCouz
  • ELCouz's Avatar
26 Jun 2011 11:03 - 26 Jun 2011 11:04
#459430
So... Dynojet kit are a scam ? I mean not worth the 100 bucks ?
Looks like HP increase at STAGE 1 STAGE 2 and STAGE 3 marketing propaganda to me!
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 26 Jun 2011 11:04 by ELCouz.
  • otakar
  • otakar's Avatar
26 Jun 2011 11:57
#459446
I would not call them a scam, but I would definitely say that they are not worth the $100. and that they are a waste of money.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • loudhvx
  • loudhvx's Avatar
26 Jun 2011 12:06
#459448
My dynojet needles are stainless steel. I do recall hearing about counterfeit (read that as Chinese counterfeit) jetting kits. I'll do a search real quick.
  • loudhvx
  • loudhvx's Avatar
26 Jun 2011 12:10 - 26 Jun 2011 12:16
#459449
www.dynojet.com/whats_new/PressReleaseKnockOffJetKits.pdf
Same link here
No mention of needle material. But the counterfeit jets all have the same size orifice regardless of the number stamped on them.
Last edit: 26 Jun 2011 12:16 by loudhvx.
  • otakar
  • otakar's Avatar
26 Jun 2011 12:23
#459451
I spent over $200 on two kits some years ago and they left a bad taste in my mouth. They may have been counterfeit or they are just doing this to cover up a screw up. I can't see someone counterfeiting this particular product and getting everything so wrong. I just can't see there being so much money in it being worth the work and effort to counterfeit this product.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
27 May 2026 13:48
#924314
Iam learning that the cv34 o.d. on the intake side are smaller diameter than the bs34. There is a 2mm difference casing horrible vacuum leaks.  I have a 83 ltd 700 that I wanted to use the bs34 and getting bad vacuum leaks. It took a good bit of time to run into this information on my particular situation.
  • Nessism
  • Nessism's Avatar
27 May 2026 17:48
#924316
Sorry to hear about the problems.
I just measured a set of CV34's and some BS34's, and both are 40mm OD at the inlet side.  Not sure what carbs you are using, but you might want to post  some photos.  Maybe you have BS32's?
