hard starting
- buz0340
hard starting
06 May 2006 08:42
hey,
my 81' kz 550 has some real nasty starting problems when its cold, so im wondering what adjustments can i do to make it a little easier. once its warm, it has no problem starting.
here is my starting procedure when cold. use full choke and hold the throttle wide open. then after a couple seconds of cranking, release the throttle and the engine will fire up for a second or two, then quit. sometimes i adjust the idle extremely high, so when it finally starts it revs really high. but sometimes i just say screw it and put some gas down one of the cylinders and i can get it goin.
i just cleaned my carbs, and synced them.
any help would be greatly appreciated
buzzz
buzzz
- btchalice
Re: hard starting
06 May 2006 11:02
does the 550 have the rubber diaphragm? my yamaha had a pinhole in one and was hard to start. after fixing that i dont even need the choke
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- oldcoldankles
Re: hard starting
06 May 2006 11:44
I find my KZ550 starts easiest if I keep the throttle just slightly cracked beyond an idle with the choke set appropriately for lower temperatures or not used at all in warmer temperatures. If I open the throttle too much the engine will not fire presumably as it is too lean.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- buz0340
Re: hard starting
06 May 2006 11:51
btchalice,
what rubber diaphram are you referring to??
buzzz
buzzz
- btchalice
Re: hard starting
06 May 2006 12:16
on the top of the sliders some bikes are vaccuum operated and some have direct pull slides
