Newbie needs help with carb off KZ1000
01 Jun 2011 13:31 #454768 by kas
Hey guys,
I recently purchased a 1979 KZ1000 LTD. I know nothing regarding the bikes history but it seems that there has been attempts at some sort of modifications. If my research serves me right the carbs that are mounted on the bike are not the factory ones. They seem to be Mikuni BS34s?
I am trying to get the bike started to find out the condition of the motor, etc.. before I start to rebuild the bike.
I haven't had any luck with starting the bike and it leads me to believe it's the carb which is causing me problems. I have spark and the motor is cranking over well. I have never worked on carbs before so I'm hoping for some guidance on getting them diagnosed and hopefully getting the bike started.
I've attached a picture of the carbs. I measured the engine side of the carb and got 34mm.
Thanks for the help,
Pete
Attachment IMG_34191.jpg not found
Attachment IMG_34101.jpg not found
  • tachrev
  • Rubber Side Goes Down
01 Jun 2011 14:05 #454773 by tachrev
Replied by tachrev on topic Newbie needs help with carb off KZ1000
Those kind of look like CV flatslides.
If they are, they are probably BST34's off a Suzuki Katana.
Build Thread
01 Jun 2011 14:06 #454776 by shizzomynizzo
Replied by shizzomynizzo on topic Newbie needs help with carb off KZ1000
I can't help you out identifying them...not the expert there.
But go ahead and tear into them! You will need a few bottles of carb cleaner and a couple hours time.
Spray all the passages clean. If there is major varnish build up from sitting, you may need to get a carb dip, but that's pretty unusual unless it's sat for a REAL LONG time.
Remove each of the jets and run some copper wire through them if the spray does not go through...it will not scratch them.
You should be able to see light through each of them when done.
Reassemble everything that you removed and re-mount them. That should suffice to get the bike at least started.
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
