do pilot jets interchange
  • toad
  • toad's Avatar Topic Author
27 May 2011 22:47
#453905
curious, are pilot jets interchangeable between 28 and 29mm carbs?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: do pilot jets interchange
27 May 2011 22:55
#453906
Yes, they should be if they resemble eachother.
Unless your taking about different manufacturers, then things get tricky ;)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • martin_csr
  • martin_csr's Avatar
Re: -
28 May 2011 09:28 - 15 Feb 2013 10:03
#453966
Last edit: 15 Feb 2013 10:03 by martin_csr.
  • Old Man Rock
  • Old Man Rock's Avatar
28 May 2011 10:54 - 28 May 2011 10:55
#453989
PM Otto for he has several sets of 29 smoothies.... He'd be able to supply you some sound advice, where to get parts/jets, possibly have a manual or something who knows.
If remember correctly, so does Craig (trianglelaguna)...
SUDCO... for info and possible jet ordering (Not sure about specific smoothie jets)....
SUDCO
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 28 May 2011 10:55 by Old Man Rock.
  • testarossa
  • testarossa's Avatar
28 May 2011 10:56 - 28 May 2011 22:10
#453991
Sorry, but I believe they do not interchange. The early 72 model VM28's use a Mikuni VM28/213 pilot jet. All of the rest of the VM28's and VM26's through 1978 use a Mikuni VM28/486 pilot. The VM29 smoothbore takes an entirely different pilot jet, Mikuni VM22/210. Click the link for Sudco's Mikuni jet info: Jet knowledge here.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Last edit: 28 May 2011 22:10 by testarossa.
  • toad
28 May 2011 11:36
#453997
thanks good information.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • TeK9iNe
  • TeK9iNe's Avatar
29 May 2011 09:08
#454117
testarossa wrote: Sorry, but I believe they do not interchange. The early 72 model VM28's use a Mikuni VM28/213 pilot jet. All of the rest of the VM28's and VM26's through 1978 use a Mikuni VM28/486 pilot. The VM29 smoothbore takes an entirely different pilot jet, Mikuni VM22/210. Click the link for Sudco's Mikuni jet info: Jet knowledge here.
They do if you have the right press! :woohoo: :whistle:
:evil:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
29 May 2011 19:07 - 29 May 2011 19:09
#454223
That Sudco information is not very accurate.
The 73 and early 74 Z1 carbs (thru Z1E-32817) use a VM28/213 pilot jet. This jet is unique to these early carbs. The later VM28's fitted to the Z1's and all the VM26 & VM28 carbs fitted to the KZ900 / KZ1000 (and Suzuki GS's) use the VM28/486 pilot jet.
The VM29 used the VM22/210 jets. THese are also shared with the VM24's on the KZ650's.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 29 May 2011 19:09 by Jeff.Saunders.
  • Polar_Bus
  • Polar_Bus's Avatar
30 May 2011 12:47
#454333
Here's a great site to identify and purchase all types of Kehin and Mikuni jets :
www.pjmotorsports.com/
Bikes:
'84 GPz1100
'06 HD Fatboy
