BS34 carb swap on a j1 motor
- meangreen1
- THIS WE'LL DEFEND...TILL THE END
24 May 2011 19:44
Hey Guys can someone please tell me a good set of carbs I can swap my BS34's with and still use the single cable set up....my bike is a 78 kz1000 frame with a j1 motor,pods,vance&hines sidewinder exhaust... Thanks
1978 KZ1000
- meangreen1
- otakar
Re: BS34 carb swap on a j1 motor
30 May 2011 11:13 - 30 May 2011 11:14
The reason is because there is not much out there that will work any better with a stock motor. I have a set of BS34s on a GPz1150 that is pushing buck-1/4 in HP and they work beautifully. second thing is that most other carbs are set up for two cables, even though as long as they have a return spring on them they will work just fine with a single cable. If you absolutely require a choice of alternate carbs than a set of VM29s would be the best choice. You will not find a set of new ones because they have not been made for a couple decades but a used set can go between about $700-$1200 if you can find them. Once you build your motor a bit more than a set of VM33s or a set of flatslides would be usable. The VM33s are a good set of carbs on engines 1075 or larger.
I just did some small mods on my BS34s when I put them on my 1150 motor. Because BS34s are venturi carbs, they flow as well as a set of 31.5mm smoothbores would but they draw better. If you are not drag-racing than there is not a much better carb than the BS34. The nice part about them is that they can be set up for either economy or speed, which ever way you prefer. Here is a picture of my setup on my 1150 motor with .420 lift cams, ported head, oversize valves, 11.25:1 compression ++++++. Here is the link to the thread.
kzrider.com/forum/11-projects/169462-bui...z1150-from-a-csr1000
Attachment DSC01510.JPG not found
Attachment DSC01509.JPG not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 May 2011 11:14 by otakar.
The following user(s) said Thank You: meangreen1
- meangreen1
02 Jun 2011 02:18
Thanks for the info...nice bike
1978 KZ1000
