Engine Forum
Engine forum is a tech forum for "Engine" topics.
Air Filter
  • 2bskor
  • 2bskor's Avatar Topic Author
Air Filter
04 May 2006 20:10
#45184
Can someone out there help me with an oem air filter number for a 1979 kz1000e1 or kz1000st. I know I can get a K&N but $77.00 is a bit much. Emgo jumps all around kz1000 but a e or shaft drive is different I guess:S
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
  • anarki650
  • anarki650's Avatar
Re: Air Filter
04 May 2006 20:27
#45190
Did some digging on google for you, found this part number referenced for the kz1000e1.
K-11013-1015
Came off of this webpage, I'm not sure if it's 100% accurate or not, but thought I'd throw you what I could find. ]
www.impex-corp.co.jp/Japanese_version/Air_filterk.htm
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • gas
  • gas's Avatar
Re: Air Filter
04 May 2006 21:00
#45198
For the 1979 KZ 1000 E1 Zedder software gives AIR CLEANER ELEMENT as part #11013-1015 and AIR FILTER ELEMENT as part # 16099-002. I haven't got a clue what the difference is between them, hopefully you 1000 guys can explain the discrepancy.:S
Post edited by: gas, at: 2006/05/05 00:02
  • TonyKZ1
  • TonyKZ1's Avatar
Re: Air Filter
05 May 2006 06:17
#45240
Hello gas, I've got a NOS K&N that I'm pretty sure will fit on your KZ1000, its at home so I'd need to check the box. I was told it would fit my '75 KZ400D, but its the wrong style for mine. Its the KA-1150 model . I can look on the box tonight and see what others it says it'll fit. If it'll fit yours and you're interested how's $40 shipped sound?
Tony
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My Mileage Tracker Page
  • 2bskor
Re: Air Filter
06 May 2006 05:23
#45457
I believe the ka1150 would fit, you say 40.00, sounds good forward your address and info to private message section. It would be sent to Canada EH!
  • TonyKZ1
  • TonyKZ1's Avatar
Re: Air Filter
08 May 2006 06:19
#45854
Thanks, info sent.
Tony
