kz650 wont start without starting fluid
  • rdk
  • rdk's Avatar Topic Author
16 May 2011 22:47
#451606
Bike was fine. Went in garage. Was working on bleeding my breaks. Was kinda cold today. Started bike. Ran it up and down street. Let it sit a while. Dont remember if it died or if i turned it off but wont start back. Spray startinf fluid in breather, starts up, stays running but wont start back up if i turn it off. I dont know, maybe it will be fine after it sits over night or something but does anyone know what would cause this? Saturday, I put seafome in gas tank. I only had about a gallon of gas so i only put half the seafoam in the tank. For all i know, the fuel level could be low but i put a small amount in and still same problem.
  • newOld_kz1000
  • newOld_kz1000's Avatar
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: kz650 wont start without starting fluid
17 May 2011 00:31
#451626
Sounds like my GS1100ex before I found my valves were way out. Hard starting, but once started ran okay, but then hard starting.
How many miles are on the bike and when was the valve adjustment checked last?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
  • rdk
17 May 2011 08:39
#451674
It only has 8000 miles. I was wondering if it could be a possible carb issue?
17 May 2011 08:48
#451675
When you say you "only put half the seafoam in the tank" half of what? I mean, how much did you add to the little bit of fuel that was in the tank. Ed
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
17 May 2011 10:25
#451692
Try putting the petcock on reserve or adding more gas.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • ultimate fighter
  • ultimate fighter's Avatar
17 May 2011 10:52
#451700
i had this same problem on my 650. Make sure the pilot circuit is clean. Have you cleaned the carbs this season? does it idle fine? Is there any hesitation in throttle response?
love building motorcycles one headache at a time
  • rdk
17 May 2011 22:20
#451811
half of the bottle of seafoam
  • rdk
17 May 2011 22:22
#451812
That sounds exactly like how it was before it would even start. I have not cleaned the carbs....thoroughly anyway. It takes forever to warm up and there is a small hesitation in the throttle response. I called a guy to take a look at it.
  • ultimate fighter
17 May 2011 22:45
#451818
Some have different ideas of what a thorough carb clean.
this is what a carb clean SHOULD look like
17 May 2011 23:38
#451829
rdk wrote: half of the bottle of seafoam
Too much! Take a look at the can. It says 1 oz. per gallon. If you estimate you only had 1 gallon of gas and you put in 1/2 a can you put in 8 times as much as recommended (1 can = 16 oz). I would empty the fuel tank, drain the carbs, and start over with a tank of fresh gasoline and no Seafoam (yet). The good news is that may be all you need to do so get her running ok again. Ed
