1975 KZ400 float adjustment help
  • madmatt1
  • madmatt1's Avatar Topic Author
10 May 2011 13:30
#450099
Can anyone send me a link to service info for these carbs, or tell me
how and where to set the float levels? I do not currently have a float
level gauge/tool so I'm also wondering if you can do it without one.
Thanks!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: 1975 KZ400 float adjustment help
10 May 2011 13:42
#450104
Search this site for "clear tube". I made mine from a pen and an extra piece of fuel line.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • JR
  • JR's Avatar
10 May 2011 19:36
#450156
Clear tube method is the only way.
Measure the fuel height. Take off the carbs. take off the bowls. measure the height of the float. Do the math and calculate how much to adjust the float to get the right fuel height. ...
There's a manual and lot of technical data her www.kz400.com/
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
13 May 2011 00:50
#450612
How does one "calculate how much to adjust the float"? I thought it was pretty much bend the tang, fill the bowls and check with the tube again, bend the tang, fill the bowls and check the tube again, a workable but not exactly precision technique. Or maybe I'm reading to much into your use of "measure" and "calculate". I've never done it myself, just asking. I've done the check, just didn't need an adjustment.
  • madmatt1
13 May 2011 12:57
#450708
Ok I get it. Well yes, you could do it that way if you have no float level measuring device. I never have heard of this clear tube method, I'll be honest I am just getting into the wonderful world of carburetor work. But anyhow, you could figure out how many mm's you are off with the clear tube, and then use a float level gauge to measure where your floats are at, and go from there, pretty much eliminating a bunch of disassembling / reassembling your bowls. Thanks for the info guys!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
