KZ 750 4 cylinder Gas Mileage
17 May 2011 18:07 #451753 by 650ed
Replied by 650ed on topic KZ 750 4 cylinder Gas Mileage
kzcafe750_24 wrote: Ic,ya I got stock gearing, and usually drive 60 to 65 mph (60mph=5000rpm). But I guess I should mention I'm still in the process of tuning, so that doesn't help, but hopefully when I get it correct, then it'll be better.
5000 rpm is high for 60 mph. I generally get 32 - 36 mpg on my stock KZ650-C1 depending on how sporty I feel, but it runs 4000 rpm at 60 mph. What sprockets are you running or is your clutch maybe slipping some? Ed
  • TeK9iNe
  • What did you do!?!
17 May 2011 19:15 - 17 May 2011 19:15 #451760 by TeK9iNe
Replied by TeK9iNe on topic KZ 750 4 cylinder Gas Mileage
Tune your mixture screws leaner (closer to stock - not highest rpm per cylinder), and it will improve your cruising speed fuel consumption dramatically, at any speed.
Quick way: turn the screws richer till the engine stumbles, then turn them leaner till it stumbles while counting the turns, then choose the midle of the two points. (subtract half your count)
Bikes tend to have the best fuel economy at the rpm point that is just full advance 3500 - 4000 rpm usually.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 17 May 2011 19:15 by TeK9iNe.
  • hugo
  • '92 Zephyr 750
17 May 2011 19:40 - 17 May 2011 19:40 #451765 by hugo
Replied by hugo on topic KZ 750 4 cylinder Gas Mileage
Kawasaki would say...: Those are not the jets we put in the bike.
Last edit: 17 May 2011 19:40 by hugo.
07 Nov 2011 17:39 #487461 by Fenian
Replied by Fenian on topic KZ 750 4 cylinder Gas Mileage
Interesting....I am keeping this tip in mind for when I upgrade to pods and 4 into 1 exhaust this winter...right now I am getting about 44 mpg with an 81 750H LTD. Lots of highway riding mostly at 110-120 kmh...ahhhh 60 to 70 mph I think. Do those little cafe racer fairings on the headlight reduce drag?
Always be wary of any helpful item that weighs less than its operating manual. (Terry Pratchett)
81 KZ750H
54 HD pan/shovel
07 Nov 2011 22:03 #487493 by JR
Replied by JR on topic KZ 750 4 cylinder Gas Mileage
Fenian wrote: Interesting....I am keeping this tip in mind for when I upgrade to pods and 4 into 1 exhaust this winter...right now I am getting about 44 mpg with an 81 750H LTD. Lots of highway riding mostly at 110-120 kmh...ahhhh 60 to 70 mph I think. Do those little cafe racer fairings on the headlight reduce drag?
When you put on the pods expect the gas consumption to increase. I went from pods to an airbox a year ago and have better consumption. I never figured out exactly what it is but then I'm filling it up with litres and riding Km..... and depending who you're talking to there's US gallons and UK gallons :laugh:
