How hard is it to rebuild my Carbs
  • Grapes5x
  • Grapes5x's Avatar Topic Author
06 May 2011 11:41
#449216
How hard is it to rebuild my Carbs for 1974 Z900?
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: How hard is it to rebuild my Carbs
06 May 2011 13:06 - 06 May 2011 13:08
#449224
If you're mechanically inclined and can follow a manual they are very easy. They are basically like an old 2 stroke carb, no diaphrams or accellerator pumps. There's a ton of info on this site. search "clear tube test" to set the floats and you can bench sync them using a wire gauge. Once bac on the bike you'll probobly want to vac sync them and obviously make minor adjustments to the air screws.
I left mine assembled and just removed the float bowles and caps to clean. Blew out all the passages with compresed air. The Sudco kits don't come with the float bowl drain o-ring and mine leaked, so you might want to pick those up along with new bowl/cap screws.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 06 May 2011 13:08 by Kidkawie.
  • wireman
  • wireman's Avatar
06 May 2011 14:42
#449229
its easy depending on condition,usually they just need a good scrubbing and gasket sets. B)
  • martin_csr
  • martin_csr's Avatar
Re: -
06 May 2011 14:48 - 13 Feb 2013 13:16
#449231
Last edit: 13 Feb 2013 13:16 by martin_csr.
  • Bluemeanie
  • Bluemeanie's Avatar
07 May 2011 09:41
#449404
This is how I did mine. I suggest you do one carb at a time.
  • Old Man Rock
  • Old Man Rock's Avatar
07 May 2011 10:50
#449415
This should give you some idea.... VM Manual included...
Carb Docs/Manuals....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Thecreeper77
  • Thecreeper77's Avatar
13 May 2011 14:23
#450725
What if your not that mechanically inclined?
1980 KZ1000
2008 Versys
  • madmatt1
  • madmatt1's Avatar
13 May 2011 14:47
#450728
I'm a firm believer that with the help of experienced others, (of which there are many on this forum!) and parts diagrams like the ones on Kawasaki.com, or bikebandit.com, (the latter of which is easier to navigate in my opinion) you can conquer just about any of these old carbs yourself. When you do get it figured out, your sense of self satisfaction will make it all worth the headaches you may incur along the way!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
