Manometer idea for carb sync's
- OKC_Kent
Re: Manometer idea for carb sync's
04 May 2006 12:15
kx_125_pilot wrote:
Just like this one steell posted a pic of, because you have a twin
link here www.powerchutes.com/manometer.asp
ok, so lets say i wanted to sync the carbs on my 82 kz440....how would i go about making one of these meters and conecting it up to my carbs?? and how do i adjust my carbs?
Cashion, OK
78 KZ650 B2 85,000+ miles
- OKC_Kent
04 May 2006 13:07
If you are syncing two cylinders at a time, do you adjust the low cylinder or the higher cylinder, or does it matter?
Cashion, OK
- BARNEYHYPHEN
04 May 2006 13:46
I think the "Ideal" is 12-16cm of mercury so, adjust as required to get both within that range then adjust either one to match the other.
- loudhvx
04 May 2006 14:57
OKC_Kent wrote:
I always adjust the one that's easiest.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- OKC_Kent
04 May 2006 17:45
I don't know if it matters much, but I thought I read somewhere you want to have the highest vacuum you can get..
Cashion, OK
- loudhvx
04 May 2006 18:16
OKC_Kent wrote:
Maybe, but that is not the purpose here. If you increase the vacuum on one, the idle will drop so you will adjust the idle higher which will then drop the vacuum on all cylinders. It's just a balancing act, you cannot determine what the final vacuum will be, that will be determined by where you set the idle speed.
You don't need any numbers on your gauge because you really don't care what the value is, as long as the cylinders are the same.
1981 KZ550 D1 gpz.
Other links.
Other links.
- N0NB
- Blue handles better
04 May 2006 20:31
OKC_Kent wrote:
Per the factory service manual. "Normal vacuum guage reading is 19 ~ 24 cm Hg, and the difference between any two cylinders should be less than 2 cm Hg."
I recall that on my SR the reading on the Motion Pro Stix came in right around 22 cm Hg at a nice low idle. It took some trial and error with the locknuts, but I was able to get them well within the 2 cm specified difference. In fact when I started, the right two were 2 cm higher than the left two with 1 & 2 and 3 & 4 being even after a bench sync.
Use the idle speed knob to get the Hg in the desired range. As the engine revs higher there will be less vacuum and vise versa.
- Nate >>
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- loudhvx
05 May 2006 08:10
It's good that they give you a number, but that is really only to find out the condition of your engine versus stock.
Since your idle speed makes all the difference, you really won't know if one cylinder is too high or if one cylinder is too low. Soon as you increase your idle, the high one will become normal and the normal one will become the low one.
Don't make it hard on yourself. Adjust the easiest one to get to, or if you want, try to adjust them such that they all end up near the middle of their adjustment range. You are just adjusting the throttle which is the same thing the idle-speed adjuster does. The idle-speed adjuster just does all 4 at once.
Post edited by: loudhvx, at: 2006/05/05 11:12
1981 KZ550 D1 gpz.
Other links.
Other links.
- fixer5000
05 May 2006 12:39
you can make your own synchroniser using 4 0-30 vacuum gauges, 4 elbows and 4 flow control type dampners. like this one i made below. its crude but it works great..steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- OKC_Kent
05 May 2006 14:02
fixer5000 wrote:
Where did you get the flow control type dampers? All the small valves I can find are kinda pricey. I'm going to buy four gages and use a simple screw and washer to squeeze down the hose and act as a damper, but I'd rather use an inexpensive valve.
Cashion, OK
- fixer5000
05 May 2006 14:09
OKC_Kent wrote:
yes they are pricey but youll only buy them once...why not get good ones. the ones im using are smc fittings. they have similar types at mcmaster car. another thought is a multi setup for an aquarium pump. they do the same thing. you just use them to calm the needles on the gauges a bit...steve
fixer5000 wrote:you can make your own synchroniser using 4 0-30 vacuum gauges, 4 elbows and 4 flow control type dampners. like this one i made below. its crude but it works great..steve
massachusetts
massachusetts
- pidaster
05 May 2006 17:27
fixer5000 wrote:
How much did this setup cost you?you can make your own synchroniser using 4 0-30 vacuum gauges, 4 elbows and 4 flow control type dampners. like this one i made below. its crude but it works great..steve
