Mikuni RS34 Flatslides Help
  • six862m6
  • six862m6's Avatar Topic Author
Re: Mikuni RS34 Flatslides Help
03 May 2011 09:40
#448510
You know, after taking a look at that info and specifically the carburetor applications section; it lists a set of RS36's as the correct set of carbs for my bike. Looking across the specs between the 34's and 36's on that sheet, the only difference is a 115 main vs a 130 main (for the KZ1000). So I would say I should probably get some 130s in my carbs, but does anyone think I may be beating a dead horse? That I really need to get myself a set of 36's and quit trying to tune a set of 34's that really aren't made for my bike to begin with? Thoughts?
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
03 May 2011 10:15
#448522
36mm carbs will not fix the problem.
34's will work fine, one you get the jetting straightened out. You could jet a set of 26mm carbs to run that engine, if you where so inclined.
If it is falling on its face when you go WOT, sounds like going with a bigger main is a good direction.
130 sounds like a big jump though, I would start with 120's. 20's for pilot jets sound good.
Hopefully someone running rs34's on a 1075 will chime in with their jetting.
Build Thread
  • six862m6
03 May 2011 10:40
#448528
That would definitely be helpful if someone is running the same setup (1075 kit, very mild head work, stock cams, pods, header). It WAS falling on it's face before WOT, well before, until I moved the needle up a notch. Still has issues before WOT now, as mentioned before, but not near as bad. But raising the needle to the last (highest) position takes it in the wrong direction. SO, going to try some of the suggestions given here and up the main jets size.... suppose to quit raining here tomorrow and Thursday, just need to see if I have the right size jets in my stash.
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
03 May 2011 17:14 - 03 May 2011 17:16
#448589
tachrev wrote: 36mm carbs will not fix the problem.
I'll chime in then since I'm running a 1075,ported head with big valves, .410 cams, pods and a header with those carbs. My bike in northern Indiana likes 1/8 turn out, 20 pilots, needle on the 4th clip, and 125 mains. With that being said, it's not your bike and therefore your jetting will be slightly different depending on elevation, fuel quality, engine condition, and so on. As for putting 36's on, that's probably a bad idea since 34's will run up to a 1197 without problems. My bike would probably run better on the low end with smaller carbs say in the 29-31mm range, which is where it runs on the street, but on the top end move over 'cuz she's coming through. :evil:
EDIT: I could also stand to drop down to 122.5 mains but I've been to lazy to do it.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 03 May 2011 17:16 by andy9802gt.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
03 May 2011 19:14
#448618
36's are def too big for a 1075 street motor. it will run fine but u will sacrifice bottom end for top.
More main please. :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • six862m6
04 May 2011 09:21 - 04 May 2011 09:26
#448765
Ok guys, did some more work on the carbs last night and found something out kind of interesting. I fibbed to everyone just slightly; I thought I had 115s in it but they were actually 120s... As I said, until just a few days ago I hadn't even messed with these carbs in over a year. I didn't remember changing the mains out but I did.
Now for the interesting part. I have 3 other sets of carbs for my bike. 2 are Mikuni VMs, one being a set of regular 26s, and one being the original set of 28 pumpers. Also have a set of Mikuni BS34s. Now, I popped the bowl off of my VM 26s to see what mains I had last left in there and I noticed something very odd... the mains' heads were very small in diameter compared to my RS's. Also smaller than what I remember as I'd played with the VMs many times in the past. So I popped a bowl off my 28 pumpers because I knew for a fact that I had left these carbs in their stock configuration since they are the correct carbs for my bike. It has the regular outer diameter head mains in it (their fuel size being 102.5s). So I popped the bowl back on the 28s and put them away and then it slowly cam back to me; I HAD changed the mains out when I first got these carbs (the RSs), a closer look at the small diameter mains revealed why; they're 145s!!
So my question for you guys on this is; do the RS carbs have their own special main jets or can I use any standard Mikuni mains that work in the VM series carbs??? A quick comparrison showed them to be identical in height and obviously the threads are the same as I wouldn't have force threaded them into my carbs. The only real difference I can see is the outer diameter of the head. Does this matter? Are you guys running standard Mikuni VM mains in your RSs?
All that being said, I re adjusted my pilot screws for an 1/8th turn out (instead of 1 full turn) after being told and reading that they can only usefully turn out a 1/2 turn anyway. I did a rough float height adjustment to 17mm as given in the RS manual vs. the 19mm that was in the other manual I was using (I will get to using the clear tube soon), and did rough sync using a couple ball bearings rolling through until they all dropped at the same time. I don't have a vacuum gauge so that may be the best that parts going to get for awhile. I also stuck the "original" 145 mains back in them and put the 120s back in my VM26s. I know, I know, those are GROSSLY too big for my bike but thoughts are that they won't prohibit the jet needle/needle jet in the overlap area of the throttle. Anyway, I want to get some 130s for them (since I was already running 120s) but I wanted to find out about this head diameter thing first. I didn't test the bike last night, just put it all back together and ready to test tonight. It was cold and rainly here last night as it has been for the better part of a month now...
Let me know on the main jets guys... I hope theres no difference and I can just use VM sytle mains as they're much easier to come by!
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
Last edit: 04 May 2011 09:26 by six862m6.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
04 May 2011 20:44
#448920
by changing the float level from 19 to 17mm u have enriched the mix. i would try the same 120's again and see what it feels like. 130's are tooo big.
i dont know the correlation between the dif mik jets but i would strongly suggest using the proper jets.
Dyno jets look the same to but they run richer than mik's.
bench float height and slide height's will be good enough to get u going. the slide height affects cruise speeds the mostly, the float height will affect everything.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • six862m6
04 May 2011 20:48
#448922
Good news! The adjustments worked out. The bike is damn close to being right now and believe it or not runs MUCH better on those 145 mains! Its actually RIDEABLE now as long as you don't constantly full throttle it from low RPMs. Obviously not right, still some stuttering at the top end, but of a different nature and a quick look at the plugs after a little 2 mile jont shows what we would of course suspect; too rich. I think 130s are definitely the way to go, maybe even 135s.
Can ANYONE chim in on the mains of RSs vs VMs??? I'd really like to get some jets on order, but I'd like to know which to go with.
Thanks guys!
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
  • DoubleDub
  • DoubleDub's Avatar
04 May 2011 20:57 - 04 May 2011 20:59
#448925
Last edit: 04 May 2011 20:59 by DoubleDub. Reason: Nevermind - not my area of expertise.
  • six862m6
04 May 2011 21:30
#448934
Ok, after some serious studying (not really) of the Sudco Mikuni parts book I answered my own question. The small round head mains that I currently have in my carbs are WRONG for the RSs. They are refered to as "Small Round Head Mains" (go figure, huh?) and have a 6mm outer diameter head. The RS series are supposed to use the "Large Round Head Mains" and have an 8mm outer diameter head. These are the same that are in the regular VM style carbs that came on our bikes as is indicated both by the Mikuni Part Number and the given Application list for them in Sudco's book. Case closed. :)
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
  • andy9802gt
04 May 2011 21:57 - 04 May 2011 21:59
#448941
Call Sudco and see what the small mains you're using now are equivalent to in the large mains and go from there. I can tell you my 34's that I bought new had 5 different mains in the box and had 125's from the factory installed and as said before I could probably drop to 122.5's and be okay.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 04 May 2011 21:59 by andy9802gt.
  • six862m6
05 May 2011 09:04
#449009
Already ahead of you. ;) Called them and left a message with Chad who called me back last night sometime after posting my last reply; he said that the RS's use the large round heads, but that the small round heads are the same flow ratings and he wasn't even sure why they (Mikuni)offered both types... They are interchangable with each other.
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
