Spitting and sputering
- Wizzard
02 May 2006 11:55
My bike is being strange when I start it up it will iddle fine untill I want to go then it will pop out the carb or carbs un till I can get it to wind up and go good then it will stop and run fairly good but will pop here and there wile I ride I'm lost have no idea carbs are clean and filter is as well. PLEASE HELP!!!!
Thanks Wizzard :blink:
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- OKC_Kent
Re: Spitting and sputering
02 May 2006 13:22
I would check everything that won't cost me money, like all the tuneup settings first.
Are the carbs sync'd and air/pilot screws set right? This can give you a stumble when you open the throttle from idle.
Are you sure the carbs are clean? Did you get all the jets and other small openings clean and clear? An idle jet might still be dirty, or even a low float level...but then you say it runs fine otherwise, but has an occasional pop here and there...mmm...are your plugs fouling?
Check the voltage at the coils, you need 12 volts.
Those are places I'd start looking, then move on to check the valve clearances.
Cashion, OK
78 KZ650 B2 85,000+ miles
- OKC_Kent
02 May 2006 13:32
DOUBLE POST, SORRY
Post edited by: OKC_Kent, at: 2006/05/02 17:06
Cashion, OK
