Idles W A Y too high
- biscuit0229
02 May 2006 07:54
I just picked this up this weekend.. 79 kz1000
I love it.. however in neutral or clutch in.. this thing revs almost like its at full throttle... I have no RPM gauge at this time... is there a quick way to adjust to drop idle.. until I can have time to bench set these.. and adjust..
Thanks
Huck
Thanks
Huck
- rammy
Re: Idles W A Y too high
02 May 2006 08:23
inbetween #2 and 3 carb there should be a thumb screw to adjust the idle. check and make sure that the cables ar not sticking also.Check the clamps on the intake boots and make sure they are tight also as a vacuum leak will cause this problem too.are the vacuun plugs on the intake boot (were you would install vacuum gauges to sync the carbs).Since you just got the bike I would spend some time and check all the nuts and bolts to make sure nothing will come apart going down the road as for it will make a big mess of you and the bike and what ever is in the way.
Good luck and be safe.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- biscuit0229
02 May 2006 09:04
thank you sir... this will help a lot... I have been thru and retightened all of the above... lol I was not wanting to take a spill...
but I couldn't pass up on this deal... 500.00 runnin.. and riding to work already...
- biscuit0229
- biscuit0229
- mstbone67a
02 May 2006 11:31
I got an 81 kz1000ltd Kinda doing the same.. But I will be doing a sync and wiring my coil direct to the battery by relay per the filebase.
Where you at?
Where you at?
- biscuit0229
02 May 2006 19:36
.. I was able to get the idle down... sounds much better now..... still will do a full bench sync when I get the chance...
pics of my work in progress to come soon..
Tipton County , Tennessee...
