1976 kz400 petcock...the impossible part?
  • gmokage
  • gmokage's Avatar Topic Author
01 May 2006 12:45
#44201
I'm building a bike and I'm stuck using a 76 petcock.The problem is that I can't find a replacement for the shot bowl gasket.
Any ideas on where to find one or alternatives would be great.
Thanks.
  • hydrolazer
  • hydrolazer's Avatar
Re: 1976 kz400 petcock...the impossible part?
01 May 2006 18:55
#44297
have you tried kz400.com?
\'79 kaw 1000 ltd
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
01 May 2006 19:01
#44300
Thanks.
I have bought one before - I can't remember if it was from eBay or BikeBandit.com, it's been a while...
I think I've seen them recently on eBay called "Petcock rebuild kit", though it's really only the gasket...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • indykaw77
  • indykaw77's Avatar
01 May 2006 19:22
#44310
Jeff @ z1 not have???????
If not.....maybe he can point ya in the right direction.
Post edited by: indykaw77, at: 2006/05/01 22:23
Kawasaki Motorcycles...because cars lean th wrong way!
  • gmokage
01 May 2006 21:43
#44352
I'm still digging around.
I didn't find anything off of kz400.com, and the web sites I have contacted thus far, including bikebandit, have the item as discontinued.
Thanks for the ideas so far, guys.
  • KitNYC
  • KitNYC's Avatar
02 May 2006 00:18
#44380
Bowl gasket? The one between the petcock switch & the fuel bowl?!?!? If that's the one you're talking about, you can replace it with a plain ol' nitrile o-ring. I was thinking a flat nitrile washer might work better, but the o-ring is holding up fine so far. Hardware store, plumbing section, buy 3 each of 3 different sizes just in case & walk out with change from your 5...
If you're talking about the gasket under the switch, AKA the rubber disk with 4 holes in it, you have 2 choices: make one, or call Z1. If you want to make it, you'll need some nitrile rubber & a good hole punch. If you don't want to make it, call Jeff at Z1 & ask if he has 'em in stock yet. He quoted me about $10 with a delay of a few days to get 'em from his supplier.
HTH,
-Kit
Post edited by: KitNYC, at: 2006/05/02 03:20
  • Biquetoast
02 May 2006 05:52
#44400
KitNYC wrote:
...you can replace it with a plain ol' nitrile o-ring. I was thinking a flat nitrile washer might work better, but the o-ring is holding up fine so far...
You know, I did the same thing when I first got my 400. It had some sort of a paper gasket in there when I got it, and was about as gas-tight as a coffee filter.
:huh:
Anyway, I tried the round o-ring first, and I couldn't get it to seal tight. As I tightened the bowl, it would flex out-of-round on me. Now in hindsight, I wonder if it was too big. Oh well, I ended up getting a flat one and it never leaked again...
B)
kz750twins.com
  • rammy
  • rammy's Avatar
02 May 2006 06:30
#44414
If you cant find the parts (o-rings or gaskets) replace the petcock.I had to replace mine because the aluminum was wore out from almost 30yrs of use and it only cost me $30 with adapter plate and about 30min.time.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • Biquetoast
02 May 2006 09:53
#44477
You did this with an early 400? These have very rare shapes, I've not heard that an adapter exists...
kz750twins.com
  • gmokage
02 May 2006 11:28
#44502
I may be building a rat-bike, but I'd gladly spend thirty bucks on a new petcock.
Do you remember where you got it?
I had the same problem with O-rings flexing under pressure in the bowl.But digging about the plumbing store couldn't hurt, either...
  • KitNYC
  • KitNYC's Avatar
02 May 2006 17:45
#44582
FWIW, I bought a large assortment of o-rings for $15 or so at Pep Boys when I realized the carb rebuild kits I had didn't come with 'em. I used a bunch of the small ones for the KZ400 carbs, I'm about to use a bunch more small ones on the Trident's carbs, & I used a big one for the KZ400 petcock. It may be worth noting that the one I ended up using in the petcock is smaller than the first one I tried. It may also be worth noting that the only reason I didn't go with a flat washer is that it doesn't leak with the o-ring in.
Cheers,
-Kit
  • rammy
  • rammy's Avatar
03 May 2006 08:23
#44774
How far apart are the mounting holes?? They do offer adapter plates with different mounting hole dimentions.So you can install a screw in type petcock.Let me know the dimentions and I will check with the guy I get all my parts.He has all kinds of odd ball shit in stock to bad he doesnt have an on line store.
