what is correct float height for '81 kz650 (CSR)?
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
12 Feb 2011 15:30
I *know* I can use the clear tube but I've got the carb bank on the bench and want to check it but have no manual.
I have searched the posts but still haven't found float height -- I want to get this sucker running today for the 1st time!!
Anyone know what float height should be, 1981 kz650 (stock everything)
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 21 Feb 2013 17:46 by martin_csr.
- TeK9iNe
- What did you do!?!
Re: what is correct float height for '81 kz650 (CSR)?
12 Feb 2011 15:45
Between 22 - 26 mm for VM type carbs. Note exactly sure for yours, but 24 would be fine, all identicle is desired. Final height when using clear tube method should be 4-5 mm below bowl edge.
Some people will say 2-3, but this ends up being slightly too rich for hot days.
Best of luck.
Best of luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
12 Feb 2011 15:49
Just saw this...
martin_csr wrote:
Yeah, this happens often, which is why taking the time to setup a jig for doing them wet style on the bench is a big time saver in the end.
Just get an old gas tank from a lawn mower or something with a shutoff, and put your carbs in a vise. Tie up or shelf the tank above the carbs, and with some clear fuel line, you're good to go.
martin_csr wrote:
I set mine meticulously dry, then checked the fuel level: none of them were the same, so I redid them wet.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 21 Feb 2013 17:44 by martin_csr.
- newOld_kz1000
13 Feb 2011 12:32
martin_csr wrote:
Hey Martin thanks for your pointer to the shop manual! I have to do a valve adjustment if I get this baby fired up today, the manual will come in handy.
I do not expect to find the tappet clearances out of spec - this CSR 650 has only 17,300 miles on her. But I do that (valve check) as part of my revival process each time, thanks Martin for the manual!
If I knew how and that it was Okay, I would add this Kz650 CSR 'H1' factory shop manual to our forum's archive under 'Kz Information/Filebase' at the top.
Anyone know the process for doing that?
Well, the best way is to do the Service Fuel Level Check: 3mm +/- 1mm below the carb body.
The float height measurement is 23mm +/- 1mm with the bowl gasket removed (page 3-4 in my manual - there's a photo). Carbs upside down and the ruler placed on the carb body's gasket mating surface.
This page has a factory manual for your bike... jarlef Z650
- KZFreak
03 Mar 2019 12:45
I don’t know if you’ve tried to adjust the valves yet, but, they utilize a shim under bucket design which requires it to be checked with the engine cold, and if any are out of spec, you have to remove the cam to swap shims. I just did mine. Now I’m trying to set float height, but, I have later model cv carbs.
Shiny Side Up!!
03 Mar 2019 13:16
You should take care of the valves before messing with the carbs. If you do the carbs first and then find some of the valves out of spec, you will need to do the carbs again. A badly out of spec valve can alter the signal that the carb gets.
You will need to chat with one of the KZR moderators about posting the manual.
- rstnick
03 Mar 2019 14:08
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
