Carb balancer tube
- Topper
Carb balancer tube
29 Jan 2011 09:45
I bought a '79 KZ750 twin recently but haven't had much chance to ride it due to snow and cold temps.
I replaced the tach cable today which of course meant I had an excuse to at least start her up
When I cut it off, there was a fair amount of vapor coming from around the carbs.
I took a closer look and it was coming from a little nipple on one of the carb holders close to the engine. The other carb holder had a nipple too but this one had a little plastic cap on it.
I couldn't find any reference to this in my service manual but from looking at the parts diagrams on Kawasaki.com it looks like there's supposed to be something called a balancer tube connecting these carb holders.
Can anybody tell me if I'm interpreting the parts diagram correctly? Is there supposed to be a tube between these carb holders?
If so, what exactly does it balance? What would happen without it (like my bike)? Would it affect idling or performance in some significant way?
Short of ordering a replacement online and waiting, can I replace this with some other sort of tubing (like fuel line)? and if so, anybody know what diameter it is?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- stonemaster
Re: Carb balancer tube
29 Jan 2011 09:59
not familiar with that model but Z1 enterprises has a carb guide section that might help you
- Rainman
- and a little Kaw shall lead them
29 Jan 2011 12:06 - 29 Jan 2011 17:42
Topper, these are the vacuum ports used for carburetor synchronization described in the manual(check adjustment - engine pg 19). It is also the port that is used if you have a vacuum fuel petcock (not standard on the 79 750 Twin). I have tried it both ways (separate plugs on each and both combined) and did not notice a difference. Fuel hose has worked fine for me. Reference picture:
Yes, it needs to be completly over the bead for no vacuum leaks.
Good luck
Jim
Good luck
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 29 Jan 2011 17:42 by Rainman.
- Topper
29 Jan 2011 15:25
Well one of mine is capped and the other is open. You think that tube is about 1/8 inch?
1979 KZ750 Twin
1979 KZ750 Twin
- Rainman
29 Jan 2011 17:40
No, it is larger than that. The small end of the brass nipple measures 5mm (.2").
7/32" or 1/4" ID hose will work. (5mm or 6mm if you like the measuring system the rest of the world uses).
Good luck,
Jim
Good luck,
Jim
Jim
Quincy,IL
Jim
Quincy,IL
- Topper
30 Jan 2011 08:40
Thanks Jim. My eyeball estimate on that was way off.
I happen to have some 1/4" fuel line I hadn't used for anything yet. I tried it on there and its just a hair big. It'd probably be OK with some little clamps, but the space is just too tight in there for clamps.
I think I'll try to find some 3/16" fuel line next time I'm in town. (That'd be about 5mm right?)
1979 KZ750 Twin
1979 KZ750 Twin
- TeK9iNe
- What did you do!?!
30 Jan 2011 09:21
The fuel line thing decreases vacuum at idle/cruise, (as viewable with colortune/manometer) thus requiring more fuel and slightly larger throttle opening to achieve normal results.
Not a huge difference, just basically drops your mileage a bit.
Vacuum nipples should be capped off to prevent vacuum loss as per manufacturer. They are for testing and balancing purposes only, and should never allow a decrease/loss in vacuum to occur.
You can make caps easily. Slide an appropriate size fuel line over the nipple, then cut the line leaving some excess to thread an apporpriate size bolt into it, to plug line.
Best of luck!
Best of luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Topper
30 Jan 2011 15:52
Thanks for the help. I picked up some 3/16" fuel line at the auto parts store and it seems to have done the trick. Fits over the bead and stays on without clamps.
I wonder how much this was effecting idling stability. Like I said I haven't really been able to ride this bike since its been too cold and icy. But it was idling a little rough and would occassionally backfire then die.
I figure a carb cleaning is needed before spring comes around. But that vacume port being open couldn't have been helping anything.
1979 KZ750 Twin
1979 KZ750 Twin
- bgmrc
30 Jan 2011 17:55
i have the same bike...and noticed the tube when i just cleaned my carbs and put em back on....
i figured it was a balancer as i have one on my quad also...
thanx for confirm
thanx for confirm
