Question about re-jetting
24 Jan 2011 11:44 #424986 by DareDevil44
Question about re-jetting was created by DareDevil44
So i have a 1981 KZ 550 LTD C2. when i got it the bike had been sitting for 12 years. i cleaned it up and got it to fire up and all, but i noticed that the previous owner had out a 4 into 1 Vance and Hines exhaust on the bike. i was wondering if there were any suggestions on whether i should re-jet my bike, and if so what are your recommendations.
24 Jan 2011 19:35 - 24 Jan 2011 19:36 #425191 by Patton
Replied by Patton on topic Question about re-jetting
Hello, DareDevil44, and WELCOME to KZr! :cheer:
Might have already been re-jetted.
Or may not need re-jetting.
Imo, jetting is best addressed LAST after all other components are known to be relatively perfect, such as ignition timing, compression, valve clearances, spark quality, fuel delivery, float bowl fuel levels, etc.
Carb fiddling absent the foregoing conditions is imo largely a waste of time and effort.
Given the foregoing, spark plug readings following a high speed throttle chop should help determine whether different main jet sizes could be beneficial.
After sync and pilot screw adjustments, primary jetting should afford a smooth steady idle and strong pull away.
Good Fortune! :)
Last edit: 24 Jan 2011 19:36 by Patton.
27 Jan 2011 23:00 #426353 by DareDevil44
Replied by DareDevil44 on topic Question about re-jetting
ok, well when you give the bike throttle then quickly pull off the engine wants to give out. i dont know if that was what you were meaning by throttle chop
