Rough Idle
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
Rough Idle
31 Oct 2010 14:00
#410115
I just brought a 1976 KZ900 with 29 mm carbs on it. The guy I got the bike from filled the tank with gas and rode it to my house. He said that he had to keep messing with the idle screw to get it to run right. I could not get it to idle right and noticed that the #1 pipe was bright red. We took the carbs off and cleaned them. I put the carbs back on and turned the gas on before putting a inline filter on. I still cant get it to idle right. I sprayed carb cleaner where the carb connects to the rubber boot and it does not affect the idle. When I spray where the rubber boot connects to the engine, it caused the engine to either idle higher or it cuts out. Does the rubber carb holders need to be replaced ? Sorry for the long entry.
1976 KZ900
2006 ZX6R
  • testarossa
  • testarossa's Avatar
Re: Rough Idle
31 Oct 2010 15:56
#410139
Kevin, I would say that you are on the right track. The carb boots tend to leak when they get old. A set of these ought to get you closer: www.z1enterprises.com/detail.aspx?ID=3245
Probably wouldn't hurt to check valve lash and spark to rule out any other sources for misfires.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • BIGKEVIN
Re: Rough Idle
31 Oct 2010 15:59
#410141
I also noticed that when I pull the plug wires off of plug #2 or #3 I good a good shock. When I pull the wire off of #1 or #4 I dont. Could this be the coil since #1 and #4 are from the same coil ?
1976 KZ900
2006 ZX6R
  • testarossa
Re: Rough Idle
31 Oct 2010 16:16
#410145
Sure could be. IIRC all of the tests for coils are simple resistance checks easily performed with a multimeter. Also you could remove the plug from the head,and leave the wire attached. Then lay the plug on the engine, and observe the spark while cranking. Should be a fat, blue spark.
2004 ZX-10R
Angola, IN
  • BIGKEVIN
Re: Rough Idle
31 Oct 2010 18:27
#410191
How do I check to see if the coil is working correctly ?
1976 KZ900
2006 ZX6R
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Rough Idle
31 Oct 2010 18:37
#410195
Other than carbs, pretty much (98%)the same manual...
OEM FSM.... FREE!
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • BIGKEVIN
Re: Rough Idle
04 Nov 2010 16:37
#410823
I took the carbs apart and found that the pilot jets were clogged. I cleaned all 4 of the pilet jets and the bike idled good. The next day it idled rough again. I took the pilot jets out and they were clogged again. How do I clean the carbs to keep the pilot jets from getting clogged again ?
1976 KZ900
2006 ZX6R
  • stonemaster
  • stonemaster's Avatar
Re: Rough Idle
04 Nov 2010 20:32
#410866
check your filter, tank AND fuel lines, even if they're new, I had crap in my new fuel lines once causing problems
  • Polar_Bus
  • Polar_Bus's Avatar
Re: Rough Idle
05 Nov 2010 03:49
#410883
Check for rust inside your fuel tank. Rust sediment is the #1 issue with carb problems ! Either use POR50 or KREEM and coat the inside of the tank.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • BIGKEVIN
Re: Rough Idle
09 Nov 2010 14:07
#411881
I just replaced the boots from the carbs to the engine last night and the bike was idling good. I started it today and noticed that the idle screw was not touching the lever on the carb at all. The bike would idle good and then shoot up to about 2500 - 3000 rpm. I could get it to idle back down to 1000 rpm by adjusting the air screws on the side of the carbs. Anyone have any ideas ?
1976 KZ900
2006 ZX6R
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Rough Idle
09 Nov 2010 14:14
#411883
have somebody else pull the plug wire off! :woohoo:
  • BIGKEVIN
Re: Rough Idle
09 Nov 2010 15:33
#411891
If the timing is not correct, can that cause the idle to surge ?
1976 KZ900
2006 ZX6R
