air screw in or out?
- brokekz
19 Apr 2006 20:34
kz 900 do you screw it or out to rich or lean it?:S big brain fart???
- savedrider
- 1975 Z1-B 900
Re: air screw in or out?
19 Apr 2006 20:59
Depends on the carbs you have. If you do have the carb type with an actual "air screw" adjustment these are typically on the sides of the carb bodies. They work just like a faucet to adjust the amount of air in the idle circuit. Open or close. In or clockwise to richen (reduce air in mixture) - out or counterclockwise to lean (add more air to mixture).
Get right or get left! <*{{{><
- rstnick
20 Apr 2006 07:14
My plugs are still black, even after the WG coil mod. Should I try raising the clip on the needles in the carbs to lower them and lean out the mixture?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- brokekz
20 Apr 2006 09:47
I would. My question was a big brain fart also..................:S
- brokekz
21 Apr 2006 15:45
She rocks out now!!!! As much as 26's will get ya.
