- Thank you received: 2098
1983 440 ltd.. novice carb rebuilding..
just a dumb question:blush: here but everyone says dont take the carbs apart from the bracket whys that? just curious i know nothing about a carb but all the information is great... my main reaso for asking is there is a little rust on the bottom of each carb and i was gonna sand it down and put a little paint on it... is it a bad idea to paint them?? I just didnt know if it could cause some of the outside moving parts to stick... thanks everyone
Most everything that needs cleaning is accessible after removing the float bowl, without requiring separation of the carbs.
Some procedures (such as for example fuel pipe removal and replacement) do require separation or partial separation by loosening the carb(s) from mount bracket.
rust on the bottom of each carb --- meaning on bottom of float bowls?
Sometimes a gas stain instead of rust.
If desired, could buff the float bowl exterior to a shine,
or even have the float bowls chromed.
Many owners buff or chrome both the carb caps and bowls.
But don't paint any part of the carbs.
Imo it looks amateurishly tacky, and won't last.
Excerpt from wgcarbs.com :
www.wgcarbs.com//index.php?option=com_co...view&id=19&Itemid=35
Paint Removal ***************************************** $65
Paint is removed when we clean. All of it must come off and this is tedious and time consuming. We highly recommend you not request repainting. Paint is not durable when it comes in contact with gasoline.
No question is dumb!
- JMKZHI
- Thank you received: 48
There's no need to blush. That's actually a good question. I believe the factory manual for some models advises not to separate the carb bodies, but that may not be applicable any more - the bike is 25+ yrs old now. Often times it's a good idea to submerse the carb bodies in solvent overnite or longer & it usually can't be done unless they're removed from the rail.just a dumb question:blush: here but everyone says dont take the carbs apart from the bracket whys that? .....
- JR
- Thank you received: 449
- swapdip
No harm in it. If you want to go ahead, you're not going to hurt anything.
- JMKZHI
Most carburetors have more than one orifice, so simply proving that the main jet is clear won't suffice for properly function carbs.
The op's carbs may or may not need to be separated. He'll have to make that determination by using his eyeballs & common sense. If the bowls & what not are gummed up or worse, then it may be necessary.
- jkufen
thanks everyone
- swapdip
Yeah I was just saying that when I clean carbs, the only reason I ever separate them is if there is an obstruction in the main fuel line. Obviously all the passages need to be thoroughly cleaned, but the majority of them can be cleaned with the carbs still united.
