1976 KZ900 Carb question? Jetting?
- Onthewater2181
21 Oct 2010 16:11 #408032
by Onthewater2181
1976 KZ900 Carb question? Jetting? was created by Onthewater2181
Hi
I am new to this forum and has been a great source of information. I am currently rebuilding a 1976 KZ900 that I got from my wifes uncle. I am almost completely there. I got the bike started and took it out for test drive. Here is a list of what I have done so far.
Cleaned carburetors
Adjust timing
install new plugs and wires.
installed new pod filters.
I am eventually going to be getting the vance and hines 4 into 1 exhaust. It currently has 4 into 2 now.
The bike is sluggish at times and has a slight popping noise when I let off on the throttle.
Could this be a issue with the pod filters?
And will I have to re-jet when I get the new exhaust?
Does anyone have this set up?
Any help would be greatly appreciated.
Cleaned carburetors
Adjust timing
- Thank you received: 2829
21 Oct 2010 16:23 #408034
by 650ed
Replied by 650ed on topic 1976 KZ900 Carb question? Jetting?
Welcome aboard. Pods will create performance problems unless you are willing to fiddle with the carbs long enough to find the magic combination of ingredients to compensate for the additional airflow. Even then, you may experience issues with rain, high wind, etc. I respectfully suggest you use the search function on this site and review any of the hundreds of postings describing the pros & cons of pods and tuning tips. Ed
- Old Man Rock
- Thank you received: 225
21 Oct 2010 16:43 #408050
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1976 KZ900 Carb question? Jetting?
Use this with your service manual for the 26mm carbs on the KZ900....
Everything you need to know about carbs, jetting, tuning...
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
