1977 kz650 pods and open exhaust... Base thoughts?
  • scumbag
  • scumbag's Avatar Topic Author
  • Lewd, Screwed, and Tattooed
19 Oct 2010 21:17
#407684
So with my recent rewire I lost my airbox and attached pods. From what I can ascertain from my plugs I am running a bit lean possibly. I am getting some stumbling and hesitation from just before half throttle. It makes good power until just before half throttle and it idles really strong just up not is no bueno. Anyone have any idea for a base line figure... Clip position, jet sizes?
sept.1976 kz650
1980 kz650
  • TerryK
  • TerryK's Avatar
Re: 1977 kz650 pods and open exhaust... Base thoughts?
19 Oct 2010 21:32
#407687
Put the baffle back in the pipe and it will be easier to jet and it will run better under a wider variety of conditions. Same with the pods. Running individual filters will make the bike much more sensitive to changes in weather.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • jga2z
  • jga2z's Avatar
  • 2 wheels good ,4 wheels bad
19 Oct 2010 21:52
#407689
this is a bit foggy to recall from 1984, but I ran my mostly stock KZ650B with drilled out air box Kerker header open with no muff. Had carbs jetted to 112.5, metering rods were 1 notch dn (rich) from mid or in mid pos. I think i remember 5 positions to them?
Ran the best it ever did this way but it was only for the strip, balls out.
currently 1982 LTD1000 UNI dual throat pods, MAC header Supertrapp muffler. Shoei fairing.
The good old days: 1977 KH 400 triple, 1978 KZ650B all the basic mods, My avatar a 1980 LTD 750, ditto on the mods
  • lobstermobster
  • lobstermobster's Avatar
19 Oct 2010 22:04
#407691
i just jetted my 81 650, i went ahead and got the dyno jet kit. it came with 118s (and 124, 122) and went to 17.5 on the pilot jets. it stutters a bit at low rpm but when you get past that it roars. its a start at least.
Also if you dont want to put the baffle in try this little mod..
www.nightrider.com/biketech/exhaust.htm
1981 kz650 w/ flux capacitor
  • scumbag
19 Oct 2010 22:54
#407698
It is baffled just not much of a baffle.
sept.1976 kz650
1980 kz650
  • Nebr_Rex
  • Nebr_Rex's Avatar
20 Oct 2010 04:22
#407707
At half throttle it would be your needle.
+ 1 on the baffle
open exhaust is for a drag bike,all high rpm
it will pull out of the corners better with a baffle installed
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
20 Oct 2010 08:06
#407743
A general rule when changing to 4to1 and pods is to up the main jet by 3 and the pilot by 1. That is just a starting point, you may need to increase or decreas the main depending upon pipe flow. But you first need to get the needle setting correct.
You do not indicate if you are using the stock carbs or not, but IIRC the stock carbs are vm24ss and came with 102.5 mains and 15 pilots. So a good starting point would be 110 mains and 17.5 pilots. I do agree that issues with mid throttle are most likely a needle issue. Since you get a stumble just before 1/2 throttle I think it is just a bit too rich. Try leaning the needle by moving the clip up either one notch or shim it a half notch. It that does not solve the issue you may need a leaner needle.
Step 1: DETERMINE THE CORRECT NEEDLE AND OR NEEDLE JET.
Whether or not your carburetor is a MIKUNI or a KEIHIN, it does not matter. This is the most important step in jetting your carburetor--period!
1. Remove the main jet.
2. Place needle clip in mid-position.
3. Start motor and run it on the stand.
Condition: Motor running and main jet out. Needle or needle jet is correct: Carburetor should run clean to approximately 3/4 throttle. From 3/4 throttle to full throttle, the motor should start to break up as a result of too rich condition.
Correction: None needed.
Condition: Needle or needle jet is too rich. Carburetor runs clean to approximately 1/2 throttle but breaks up before 3/4 throttle as a result of too rich condition.
Correction: Mikuni replace needle jet with next leaner and test again. Keihin replace needle with next leaner diameter and test again.
Condition: Needle or needle jet is too lean: Carburetor runs clean beyond 3/4 throttle and has an erratic throttle response.
Correction: Mikuni replace needle jet with next richer and test again. Keihin replace needle with next richer diameter and test again.
The emphasis here is to find the correct needle or needle jet diameter, which will allow more fuel to pass than is needed but not so much that the needle itself has no control below 3/4 throttle.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • scumbag
20 Oct 2010 11:13
#407764
So where would be my best place to source jets?
sept.1976 kz650
1980 kz650
  • gd4now
  • gd4now's Avatar
20 Oct 2010 12:33
#407780
I am sure there are many online locations but I would suggest Z1Enterprises
www.z1enterprises.com/
1977 KZ650 B1
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
20 Oct 2010 13:18
#407787
gd4now, do you suggest running it on the stand because you are putting it in gear or so that the bike is as level as possible, or were you not even talking about the center stand?
  • gd4now
  • gd4now's Avatar
20 Oct 2010 15:56
#407820
Was not suggesting you put it in gear. Did mean to have it level as using only side kickstand can effect level of fuel in bowls.
1977 KZ650 B1
  • seanbarney41
20 Oct 2010 19:23
#407887
Whew, that's a relief. Gettin' into the mains, or even the needle, with it in gear on the centerstand sounds terrifying.
