- Thank you received: 6
Sea Foam
- grumpy56
18 Oct 2010 05:09 #407376
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Sea Foam was created by grumpy56
I use about 5 or 6 ounces of sea foam in my KZ1000J at every oil change (1000 miles). What I usually try to do is load it up prior to riding in order to use alot of the gas in the tank. Unfortunately, things do not always go as planned and that tank is probably going to sit there for 3-4 weeks. Any impacts do you think? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Bluemeanie
- Thank you received: 14
18 Oct 2010 05:50 #407384
by Bluemeanie
Replied by Bluemeanie on topic Sea Foam
Should be fine. From what I understand, sea foam is also a very good fuel stabilizer.
- otakar
18 Oct 2010 06:10 #407385
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Sea Foam
Here are a couple of past threads to help you out.
kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=398687
kzrider.com/index.php?option=com_kunena&...d=2&id=399614#399766
kzrider.com/index.php?option=com_kunena&...=13&id=385474#385881
Sea Foam was originally designed to be used in two stroke outboards. To stabilize the gas, deal with excessive water condensation and so forth. Sea foam was once a better product than it is now, thanks to the EPA. There are better products out there today though.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- grumpy56
18 Oct 2010 17:17 #407495
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Replied by grumpy56 on topic Sea Foam
Thank you both. I won't worry about it now.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
