which rs carb for a 1260
- School Teacher
13 Oct 2010 23:17 - 14 Oct 2010 12:24 #406535
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
which rs carb for a 1260 was created by School Teacher
for a 1260 with a ported head and 435 cams that is intended for a street strip bike(a weekend bike not a daily rider) would you go 34mm or 36mm flatslides?
Also if you were to turbo it would the carb size change? would smaller be better or bigger or same as a normal breather? thanks
1980 kz1000G1
Last edit: 14 Oct 2010 12:24 by School Teacher.
- racer54
- Thank you received: 114
14 Oct 2010 15:02 #406643
by racer54
Replied by racer54 on topic which rs carb for a 1260
Mr. Cavanaugh can probably give better advice on the carbs but personally, on that set-up, I would go with the 36mm. 34's might give better throttle response while riding around but the 36's should be better for the racing part of the deal. As for if you went turbo, and I will asume it will be a normal set-up with the turbo behind cylinder and not a blow-through style, get a 42mm HSR Mikuni. This carb is fantastic for this set-up. Actually about the only carb anyone uses for a turbo on a KZ.
- DoubleDub
- Visitor
14 Oct 2010 16:55 #406662
by DoubleDub
Replied by DoubleDub on topic which rs carb for a 1260
www.mrturbo.com/catalog/106_carbfuel/carb_fuel.html
A source for the Mikuni HSR.
I haven't seen many (any that I can recall) turbo setups with a 4 carb install. Most simplify to a single carb. I'm assuming this is mostly due to space and ease of tuning.
- racer54
14 Oct 2010 17:15 #406668
by racer54
If you use a blow-through system you still use the carbs unless you switch over to injection of some kind. Blow-through will generally make more HP but on these older bikes, it's a lot more work. Newer bikes use the blow-through systems.
- DoubleDub
- Visitor
14 Oct 2010 18:12 #406685
by DoubleDub
Don't the blow-through setups require specific carbs with pressurized float bowls or something similar?
- larrycavan
- Visitor
14 Oct 2010 18:55 #406710
by larrycavan
Replied by larrycavan on topic which rs carb for a 1260
I think Racer54 is right on the money
N/A 1260 motor with good head for race use, Mikuni carburetor.... RS38
Street / Strip....RS36
RS34 can deliver enough CFM for the job and would give awesome midrange. However for the money and future growth potential.....RS36 would make sense.
Typical ported J w/ stock valves should be in the mid to high 90's CFM at 10". I just posted results of RS34 flow test in another thread.
- racer54
14 Oct 2010 19:05 #406714
by racer54
I'm not a turbo expert by any means, but I have heard that on a blow-through the bowls have to be pressurized but I ahve read that isn't necessarily true. Don't know why though. I know some use CV carbs. I hear some run a tube to the float bowl to pressurize the bowl. Maybe it depends on the boost pressure run?
