KZ650 C2 proper winter storage
- bloglos
Looking for some advice on proper storage. I'll be storing the bike in a non heated garage for the winter and I just wanted to make sure I was doing everything I needed to do so I won't have any problems in the spring.
I'll make sure it's off the wheels and properly covered while stored, but I'm not too sure if I should drain the fuel completely from the tank and carbs or if I should fill it right up and put some fuel conditioner in the tank.
Also, should I change the oil before I store it or does this really matter?
Anything else you folks can think of? Any advice would be greatly appreciated.
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
- RonKZ650
- Thank you received: 241
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Ride the bike until it is fully warmed up. Drain the oil, then change filter and install fresh oil. Start bike, and let run for about 15 seconds.
Wash the bike completely. Remove all water and wax everything you can.
Remove the battery, and bring it into a warm place to be charged 1 a month, or put on a "battery tender model" charger.
Add an appropriate fuel stabiliser to a full tank of fresh gasoline. (NOT if bike is fuel injected - drain gas). Drain the carb bowls, then turn gas back on to get stabiliser into bowls. Run engine for about 15 seconds.
Remove all the plugs and add about 2 teaspoons oil to each cylinder. Crank the engine for about 3-5 seconds to disperse oil in the cylinders. Re-install plugs.
Check tire pressures. Move the machine to the storage position, then center stand/raise the bike so that BOTH wheels are off the ground. Use either jack stands, wood blocks, whatever, just make sure that both tires are 1 inch/more off the ground.
Cover the entire bike with an old bed sheet. DO not use rain covers/heavy material/plastic! It must be light/cotton and breath well. It is just to stop dust and moisture form accumulating.
BEFORE you start bike in spring:
Once bike is on ground - check tire pressures.
Check all fluid levels.
make sure battery is fully charged.
Fill tank with fresh gasoline. Discard old treated gas properly.
perform a regular tune-up/get ready to roll.
Do it, just DO IT.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- wargoth
Combustion inside the cylinders causes deposits to form in the oil via blow-by. This causes acids to build in the oil, promoting corrosion in the metal parts of the engine. It is always a good idea to change the oil prior to storage. This is why there is a time change specified for oil, in addition to a mileage requirement. Usually the recommended period between oil change, related to low usage, is 3 months.
If you dont believe me, get some litmus paper and test some new oil and compare the Ph versus used oil. This is also easy info to get from oil manufacturers of the web.
Also, rather than using motor oil in the cylinders, try using some engine fogging spray. It is available at most auto parts stores or a boat supply. Remove the air filter and spray the fog directly into the intake while motoring the starter. Grounding the coil wires at #1 and 2 cylinders will keep the motor from starting while doing this. When done reassemble all the stuff you took apart. This will coat the inside of the carb bores, cylinders, pistons, valves and seats, and even a little on the inside of the exhaust.
Also always warm the bike up to running temp after washing, this will insure that all water is out of the exhaust and no pools on the engine.
- Capt America
- Born Bad
- Thank you received: 1
Get your wheels off the ground, but then reduce the tire pressure to about 10 lbs or so, just enough to keep them seated to the bead. If you leave them at the normal pressure in a cold climate like Canada Eh, you can find yourself with unwanted sidewall cracks come spring. Rubber is expensive. Just remember to refill them come spring.. chuckle.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- bloglos
- Thank you received: 2829
- RonKZ650
- 550A2
- keep the shiny side up
The best advice I can give is don't store it. The weather where I live prevents me from riding during winter months too, but instead of storing my bike for months I start it up about every 2 weeks and let it run for about 20 minutes. This has served me very well for the past 33 years. It keeps oil on the cylinder walls and other vital places, cooks of any condensation, keeps the carbs from gumming up, keeps the battery charged, and maybe most important, makes me smile knowing I'll be able to ride as soon as Spring arrives. Do keep the fuel tank as full as possible, and it doesn't hurt to put some Sea Foam fuel treatment in the tank
X2...i was going to say that but Ed already said it....I do the same thing, but not for the past 33 years hahah. :lol:
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
